Carpeting - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-06-2018, 12:30 PM   #1
Rewards Points: 137
carpeting
Removed old carpeting to find and older carpet underneath. This one was glued down onto plywood. After pealing the carpet and scraping the under padding that was left behind, there is a residue of glue. It is smooth. Does the glue need to be removed before re-carpeting. I see no reason to glue the new carpet down.
Thank you for any help
debd is offline   Reply With Quote
Old 01-06-2018, 03:41 PM   #2
Rewards Points: 6
Re: carpeting
Gotta love surprises like that.
Just do your best to get the floor flat, eliminating irregularities that poke up higher than 1/8". The glue won't hurt anything to be left there; your new carpet padding will cover it.
Carpet typically does not need glued down
Sent from my SM-J730GM using Tapatalk
w0j0 is offline   Reply With Quote
Old 01-06-2018, 09:43 PM   #3
Rewards Points: 137
Re: carpeting
Old 01-07-2018, 07:08 AM   #4
Guapo
Rewards Points: 11,950
Re: carpeting
Are you sure that you want to use carpet again? I shampooed carpets on & off for 23 years. They just hold dirt & the chemicals, in new carpet is not good for young children or pets. Keep that in mind.
Guap0_ is offline   Reply With Quote
Does new carpeting require new pads? Toller Flooring 2 02-15-2013 10:39 AM
Carpeting over uneven surfaces FirstAndTen Flooring 1 02-26-2011 09:13 AM
Sheetrock dust under carpeting in basement... Please help. ben319 Building & Construction 7 09-15-2009 03:35 PM
Stairs- Carpeting against stringer/drywall mjkpainting Carpentry 4 09-13-2009 11:35 AM
Carpeting Stairs - Tips 'n' Tricks? DanTheMan Flooring 1 08-20-2008 08:58 AM
