Can Plywood Be Used As A Leveling Component For A Quartz Counter Top Installation? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By chandler48
Old 10-11-2018, 04:56 PM   #1
Can plywood be used as a leveling component for a quartz counter top installation?
We have beautiful cabinets and have ordered quartz to replace the countertops... the guy came to make the template and the cabinets are not level... can we use plywood (1/4 “) on the top and add shims where necessary? The cabinets are off about a half inch . The quartz thickness is 3cm... any information would be greatly appreciated
Elle6931 is offline   Reply With Quote
Old 10-11-2018, 09:48 PM   #2
Rewards Points: 4,170
Re: Can plywood be used as a leveling component for a quartz counter top installation
I would start by asking your installer what he recommends. If more than 1/4" low, plywood might be ok as a shim.
Who installed the cabinets this poorly? Can they come back and fix their work?
stick\shift is offline   Reply With Quote
Old 10-12-2018, 03:36 AM   #3
The cabinets are original to the house... 30 years.... thank you for your response... I will check with the installer of the quartz installer.
Old 10-12-2018, 04:42 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 4,312
I would attempt to level the cabinetry first. Shimming something as heavy as stone will tend to crush the shims and could lead to cracking. Once the old countertop is out, release all the screws holding the cabinets to the wall and shim them from the base to get the half inch rectified.
firehawkmph and stick\shift like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Quartz Kitchen Counter Problem meontheweb General DIY Discussions 16 08-26-2018 09:27 AM
Leveling for Laminate Installation margog85 Flooring 4 03-20-2011 04:08 PM
counter top installation bstroutman Kitchen & Bath Remodeling 5 10-17-2010 12:03 AM
plywood underlayment installation interplexr Building & Construction 1 02-08-2009 08:45 AM
Basic T&G Plywood Installation Mablamb Flooring 5 02-04-2008 09:17 PM
