Cabinet Drawer Glides - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jlhaslip
Old 04-08-2018, 01:25 PM   #1
Rewards Points: 1,466
Has anyone ever seen drawer glide bearing replacements available?
Old 04-08-2018, 01:46 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Cabinet Drawer Glides
Can you see a Make and Model number on the slide?
Might be easier / cheaper to swap out the slide mechanism complete.
Gregsoldtruck79 likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-08-2018, 02:58 PM   #3
New glides have replaced those pictured but that ain't easy for an old man. Replaceable bearings and putting the rails back in the original screw holes would be much easier for me.
All I can find for identification is KV #1300 D.L. and KV # 1300 C.L. and K V seems to translate to Knape & Vogt which there complete glides are still available but it's anyone's guess if they are the same glides as was made 30 plus years ago.
Old 04-08-2018, 05:34 PM   #4
Rewards Points: 1,406
Do the roller wheels have a expanded rivet for an axle or a bolt threaded in from the back ? If it is a pressed in rivet, it could be worse putting on a new roller than changing the track. A bolt in would be much easier to change.
Gregsoldtruck79 is offline   Reply With Quote
Old 04-08-2018, 05:44 PM   #5
Rivets but I would attempt to locate and possibly use stove bolts. May work and may not but sometimes I'm a brute for punishment and would like to try if I could find replacement wheels/bearings.
Old 04-08-2018, 05:47 PM   #6
Rewards Points: 334
Those are from the 1970's! I think they have served admirably and deserve to be retired.
Tymbo is offline   Reply With Quote
Old 04-08-2018, 05:52 PM   #7
Well, then all you need is the roller bore size and the diameter and width of the wheel. There are places that sell just the rollers, but matching up your numbers with theirs....
Ebay has them and
http://www.drawerslideshop.com/prime...ing-pack-of-2/
https://www.homedepot.com/p/Prime-Li...7228/100142874
Old 04-08-2018, 05:58 PM   #8
There are places that sell just the rollers, but matching up your numbers with theirs.... may make a man want a stiff drink.
I've not been searching in the right places to find just the rollers I guess.
Make cabinet hole bigger for warming drawer sophiegirl Carpentry 2 01-17-2012 06:47 PM
Ideas for installing drawer glides for cabinet w/o side beetz12 General DIY Discussions 5 07-11-2010 10:13 PM
Task force 5 drawer tool cabinet whataboutj Tools 1 05-11-2010 12:41 PM
Drawer Slide for Cabinet w/o back george0410 Carpentry 2 04-08-2010 05:53 PM
