Cabinet Depth Over Washer And Dryer - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-17-2014, 10:18 AM   #1
Cabinet Depth over Washer and Dryer
My washer and dryer come out from the wall about 34". I want to put 12" upper cabinets over top, but think they might be a bit of a stretch to reach.
Is there any way to put a 2 to 4" frame behind to mount the cabinets to and would be be advisable or not...? The one exposed end of the frame would need to be covered with a filler.
Sunshyne is offline   Reply With Quote
Old 08-17-2014, 11:03 AM   #2
Rewards Points: 996
yes, it is a stretch. and yes, you can build them out. i built out 2 upper cabinets in my kitchen, to get the stagerd look i was after.
Fix'n it is offline   Reply With Quote
Old 08-17-2014, 11:55 AM   #3
Did you just build out with 2x4s? I think if it was just one cabinet (to get the staggered look), the weight on the frame might not be too bad, but my run of cabinets is 75". Any thoughts?
Old 08-17-2014, 03:31 PM   #4
Rewards Points: 17,890
Considered using lower cabinets instead of uppers?
Lots of cabinet company's make different depths of uppers.
Old 08-17-2014, 05:57 PM   #5
Interesting thought Joe, but I don't think I want 24". I can look into ordering some custom ones, but I was hoping to use stock ones. Thanks for the suggestion.
Old 08-17-2014, 06:59 PM   #6
Rewards Points: 996
i had to get excact spacing, so i cut boards.
your issue is a piece of cake. say 3 1/2" is good for you. make a frame using the 2x4's. stand them on their sides and make a square box. the side boards cover the ends of the long boards.. then cut 2 more long boaardds. lay these flat inside the frame at the top and bottom, nail/screw them in. these 2 boards will then be screwed to studs in the wall. then you screw the cabinets to the frame.
paint the side boards.
The Following User Says Thank You to Fix'n it For This Useful Post:
Sunshyne (08-17-2014)
Switch Washer & Dryer Position? Anianna Appliances 5 12-12-2012 10:55 PM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
Countertop over washer and dryer. Depth? Need HELP!!! sandyman720 Building & Construction 7 12-20-2010 05:02 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
