Building Out A Bathroom Wall. - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-13-2015, 03:21 PM   #1
Rewards Points: 8
building out a bathroom wall.
hey i just put a new bathtub in an alcove. and on my backwall (the one that meets drywall) i got about 5/8" of a gap between the wall and the tub. since im tiling the surround with 1/2" cement board there was gonna be a gap between the cement board and the tub. i was wondering if i could just put 1/4" sheet of plywood over the entire wall first. that way the cement board will hang over the lip of the tub a bit and it will also be flush with the drywall i will be putting up.
is this ok to do this? i dont want to have issues with my tiles down the road. the wall is relatively straight as is.
louiedogg is offline   Reply With Quote
Old 09-13-2015, 03:30 PM   #2
Rewards Points: 5,348
If the gap is 5/8", the minimum spacer I would add is 1/2". You can just rip 1/2" strips of plywood and attach it to the studs.
Ron
B. Franklin 1759
Old 09-13-2015, 05:49 PM   #3
Rewards Points: 8
hmm not sure if i got that much clearance, toilet is pretty close to that wall as is. but ill see what i can do.
so theres absolutely nothing wrong with plywood under cementboard?
Old 09-13-2015, 05:55 PM   #4
Retired Moderator
Rewards Points: 7,174
Most of us think of the 'Back Wall' as the flat wall behind the tub---
Are you speaking of the plumbing wall? One of the 'sides' ??
Old 09-13-2015, 05:57 PM   #5
Rewards Points: 8
no.. the plumbing is in the half wall in the alcove, the long side wall of the tub is good, but the back of the tub wall is what im referring to. beside the back of the tub sits the toilet. so i would build that entire wall out so the cementboard sits flush with the drywall behind the toilet.
Old 09-13-2015, 06:12 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 708
So, you're saying the tub end wall?
Toilet's can be purchased for a 10" set
Old 09-13-2015, 08:12 PM   #7
Rewards Points: 8
what do you mean a 10" set?
Old 09-14-2015, 05:23 AM   #8
Retired Moderator
A picture would help---
Back wall is 5 feet wide---side walls about 3 feet---
Old 09-19-2015, 11:05 PM   #9
Rewards Points: 2,494
If all you need is 1/4", when you buy paint from homedepot, grab a handful of longer paint stir stick. Make a couple of trips and you don't have to buy a whole sheet of ply. You just want a spacer, not a new layer of wall. The spacer does not have to be continuous the entire length of the studs.
carpdad is offline   Reply With Quote
Old 09-20-2015, 04:02 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 9,264
Toilets normally have the center of the drain designed to be 12" from the wall. In other words, if you are picking the spot where the toilet drain will go, you measure 12" from the wall and that is the center of your drain.
A 10" set is a toilet that is basically 2" shallower in the back. Gives you 2" more in front.
Recessed nitch depth along bathroom wall miamicuse General DIY Discussions 1 03-07-2013 06:52 PM
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 04:56 PM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 10:14 PM
bathroom sink & wall dknarnd Remodeling 1 01-24-2010 10:56 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
