Building A Gas Firplace In A Room Without One - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 1 Post By Bud9051
  • 1 Post By Bud9051
  • 2 Post By Old Thomas
  • 1 Post By scgamecock
  • 1 Post By gkreamer
  • 1 Post By Nealtw
Old 09-15-2020, 07:39 AM   #1
Rewards Points: 22
Building a gas firplace in a room without one
Hey guys! I want to put a vent less fireplace in my living room. The only place I have to put it is an interior wall. Can I do this with a vent less fireplace without having a chimney or some other type vent through the wall or the roof?
If I can do this is there any instructions or YouTube video's on what material I need and how to do it? I have done a google search and looked on YouTube but cant find anything related to what I'm trying to do.
I hate the electric ones. They look cheap even the high dollar ones.
Wade
scgamecock is offline   Reply With Quote
Old 09-15-2020, 08:45 AM   #2
Rewards Points: 308
Re: Building a gas firplace in a room without one
Too much bad information about ventless gas units they aren't safe.
Is there a 2nd story above this room? Could you go up through the roof?
Bud
dj3 likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 09-15-2020, 09:14 AM   #3
Rewards Points: 22
Bud
Unfortunately yes there is a second story. I don't really have other options. As far as bad information, what have you heard? I definitely don't want to introduce a safety risk.
Wade
Old 09-15-2020, 09:52 AM   #4
Rewards Points: 308
In your position as a consumer it is difficult to sort out the pros and cons. The no-vent industry obviously defends their products despite the potential issues they present. The primary one is a fouled combustion process that begins to emit Carbon Monoxide (CO) which is an odorless gas that can be fatal. We lose people every year here in Maine from CO although I have not read the source to be a no-vent FP.
Many will argue they are safe, I would not and my trade deals with indoor air quality. In addition to CO the combustion process produces other byproducts including large quantities of moisture. Here's some reading.
https://www.chimneychampions.com/blo...ss-fireplaces/
Bud
dj3 likes this.
Old 09-15-2020, 11:36 PM   #5
Rewards Points: 5,282
Carefully read the listing data for the ventless unit. If installed correctly you will have a small unit in a large room with a window open. I would not have one. No matter how clean it is supposed to be, you are still breathing the products of combustion. Someone develops respiratory problems, will you ever know for sure that the ventless combustion was not a factor?
Bud9051 and dj3 like this.
Old Thomas is offline   Reply With Quote
Old 09-16-2020, 10:35 AM   #6
Rewards Points: 22
Thanks guys! You have talked me out of it. I will just make sure that my next house has one. I hate not having one!
Wade
Bud9051 likes this.
Old 09-16-2020, 02:24 PM   #7
dj3
Rewards Points: 342
Wade
Smart decision !
dj3 is offline   Reply With Quote
Old 09-16-2020, 02:58 PM   #8
retired framer
Rewards Points: 924
Wade
Do you have a place in a closet upstairs that you could steel 16x16 for a vent above where you would want a FP?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 09-16-2020, 04:33 PM   #9
Naildriver
chandler48's Avatar
Rewards Points: 474
More of today's vented gas log fireplaces can be vented to a wall rather than up through the roof, as long as there are certain clearances. They don't look all that bad.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 09-17-2020, 09:48 PM   #10
Rewards Points: 12
I'm not an expert, and I'm not trying to argue. We had a propane fueled ventless fireplace in a house we owned for 8 years. We never had any issues and the CO detector never alerted.
The fireplace was in the living room and we could heat the house (1400 sq ft) without needing to run the heat pump. We bought it from Home Depot along with a nice wood mantle for about a grand. Used 2 100lb propane tanks.
We did not live where winters are extreme (Lake Anna VA) or very long. We also did not have to run it every day. It really did a great job heating our house.
Just my own experience.
Sent from my Pixel 4 XL using Tapatalk
Nealtw likes this.
gkreamer is offline   Reply With Quote
Old 09-17-2020, 11:15 PM   #11
Rewards Points: 308
One of a kind examples can be dangerous. Certainly many ventless units are in place and working fine. But they do fail and they do present a risk for which authorities have decided that risk is too high. CO detectors come in many varieties and even the best are slow to identify a problem.
For people who want to avoid the risk they just choose (when possible) a vented heater or other option.
Bud
The Following User Says Thank You to Bud9051 For This Useful Post:
gkreamer (09-19-2020)
Old 09-17-2020, 11:41 PM   #12
retired framer
Rewards Points: 924
Bud
Don't they cause moisture issues too?
figure 7-14
Old 09-17-2020, 11:47 PM   #13
retired framer
Rewards Points: 924
This is typical here
chandler48 likes this.
figure 7-14
Old 09-18-2020, 06:13 AM   #14
Rewards Points: 12
That's what we had in our last house, a vented natural gas fueled fireplace. Now we have a conventional wood burning fireplace.
Nealtw likes this.
