Brick Fireplace - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-30-2018, 06:35 PM   #1
Rewards Points: 2
Brick fireplace
My house was built in 1979 and has siding on the outside with a crawlspace. I decided after my neice almost cracked her head on my hearth that's an unreasonable 10" high and sticking out 16 from the fireplace to remove it and put in a nice floor level black slate hearth and refacing the brick with wood. The problem I ran into when the side trim came off is that it looks like the bricks aren't even attached to the house. The bricks are leaning outward a quarter inch away from the wall at the bottom and an inch and a half at the top. it looks like it's got drywall behind it my question is, is it safe to take the bricks down and then I'll just start over with a drywall?
Sent from my Pixel 2 XL using Tapatalk
coolkat131313 is offline   Reply With Quote
Old 09-30-2018, 07:08 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Re: Brick fireplace
Did you put a 4' level on the face of the brick to see if the fireplace was plumb, or were you going by the trim molding scar? Brick is really only a veneer and has little supportive value. Most likely you will see plywood and lath behind the brick if you were to take some down. However, I understand that is not what you intend to do. Do you have a picture of the hearth so we can see what you see?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
coolkat131313 (09-30-2018)
Old 09-30-2018, 07:33 PM   #3
Rewards Points: 2
Re: Brick fireplace
At the moment there is no hearth. I've already taken it, but I'm left with this until I put the slate down. Please ignore all the Electronics I removed the shelf they were on to take the side trim down off where the wall met the brick. It is a wood burning fireplace but we do not use it. If it's safe to just rip all the bricks down I'd rather just do that and start fresh and have it flat against the wall. I was just thrown off by finding that it wasn't attached to the wall. It wiggles if pushed on. I'd like to do something like this if possible. See pics attached. A mantle like the second pic with wood backing like the 3rd except the hearth will be floor level. Thanks for the info.
Old 09-30-2018, 07:50 PM   #4
Naildriver
chandler48's Avatar
Re: Brick fireplace
If you keep it a wood burner, door number two won't work. There is a triangulation factor you must adhere to in order to keep your mantel at the right depth in relation to the firebox opening. If the brick is moving, then it may be best to take it down and redo the facade.
Larry......
Tore off brick fireplace facade and found this thelivingna Concrete, Stone & Masonry 14 03-15-2018 10:48 AM
mounting tv to brick fireplace Oddjober Home Theater 7 02-14-2018 01:17 PM
Re-facing brick fireplace - help needed cfredo3 Concrete, Stone & Masonry 2 12-16-2017 12:41 PM
Fireplace remodel - replacing brick facing cumak Concrete, Stone & Masonry 8 11-22-2014 08:35 PM
Seeking help and advice with hideous painted brick fireplace sparkler22 Painting 12 12-03-2011 06:46 PM
