Bifold Door Install Help - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-23-2014, 11:54 AM   #1
Rewards Points: 22
Bifold door install help
Ok guys, I know at some point this has be covered but I've googled it and really can't find an answer.
My wife and I want to replace our sliding closet doors with bifold. However, the actual left to right opening is 59" wide. Lowes sells 29.5" wide bifolds but this would make it exactly 59" with two. Wouldn't I need like 29 1/8 or so to make sure there's enough clearance all around? Or am I thinking this wrong?
I would rather not have to cut the doors to fit and I see there's lots of people with the same width closet doors. I would think this would be an easy replace.
Thanks - Paul
Sent from my iPad using Tapatalk
PWAustin is offline   Reply With Quote
Old 11-23-2014, 10:52 PM   #2
Rewards Points: 2,438
Bypass doors have an overlap in the center and bifolds have none, so they are framed differently. You don't want to cut the bifold doors too much because you can weaken the wood where the pins are recessed.
This is some time ago since I saw them in a catalog, but I think there is bifold hardware that does not use recessed pin, so you can make some cuts to the doors. One name may be Grant. Another is Hettich. Hope that helps.
carpdad is offline   Reply With Quote
Bifold cabinet doors with non-standard height opening python-django Carpentry 4 02-08-2013 08:56 AM
Bifold door size question? gmhut Carpentry 3 10-02-2012 04:20 PM
Opinions, bypass or bifold doors Michaelpro Windows and Doors 3 03-14-2012 11:00 AM
Replacing mirror bifold doors Mamba Windows and Doors 2 09-28-2011 12:58 AM
how to frame for bifold door BlueBSH Building & Construction 7 09-21-2010 02:52 PM
