Best Way To Add Exterior Window Trim? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-17-2017, 04:04 AM   #1
Rewards Points: 2
Best way to add exterior window trim?
Sorry if this is a blatantly obvious topic. I did a quick search and didn't come up with much and need to get this rocking and rolling.
I'm a roofer and have have done a fair amount of 'diy home improving' (loft in shop, carpets and hardwood through, redid the yards and fence etc etc). . I'm capable but no experience with the detail on exterior trim work.
So the idea is this - Gonna add stone veneer in the highlighted area below and now I'm contemplating adding craftsman style trim to give it a more completely look. Would it be best to cut back the lap and redo the detail for the new trim or could I go over existing siding? I'll be color changing the house this summer, so I'm not overly concerned with ripping it apart, but I don't want to go above and beyond to the extent that I'm wasting time.
First pic is the height of where the stone will go. Second is a close up of the windows.
Any input is appreciated!
Moises360 is offline   Reply With Quote
Old 03-17-2017, 05:55 AM   #2
Rewards Points: 17,912
Re: Best way to add exterior window trim?
There's not enough room to add the trim, it will be to close to the inside and outside corners.
Old 03-17-2017, 06:52 AM   #3
Rewards Points: 2
Since you're adding stone, all the trim and corner pieces on the lower portion are going to be removed. Take the outside corners completely off. Bevel your trim legs so they wrap completely around. When you get to the ends of the windows, remove the inside corner molding. Run your trim all the way to the corner. Bevel the legs so the edge is 90* to the wall it runs into. Install a j-channel against the trim as a terminating edge for the siding on those 2 sections of wall, the one where the door is and the one all the way on the left. You will most likely want to just replace all the siding. It's a small amount and will be much easier to put in the new j-channel.
Sent from my iPad using Tapatalk
gary.bruzzese is offline   Reply With Quote
Removing latex paint from wood trim ulbass Painting 8 09-13-2017 05:46 AM
Question about hardiepanel/T-111 and window trim Alan Roofing/Siding 4 08-22-2014 09:06 PM
How To Seal Tyvek Terminations At Wood And Composite Trim? gunner666 Roofing/Siding 5 08-06-2014 01:52 AM
Old Flooring and Trim Identification and Refinishing BungalowBaby Flooring 8 07-02-2011 06:17 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
