Best Items To Clean Inside Of Old Iron Clawfoot Tub? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 1 Post By Guap0_
  • 2 Post By Guap0_
  • 1 Post By de-nagorg
  • 1 Post By SeniorSitizen
  • 2 Post By SeniorSitizen
  • 1 Post By LadeeDIY
Old 03-25-2018, 02:27 PM   #1
Rewards Points: 136
Best items to clean inside of old iron clawfoot tub?
I am holding off getting the inside reglazed due to cost. The porcelain coating looks a little dirty in a few places inside. There is no rust showing through thank goodness. There are no dings or chips either
I would like to gently deep clean, but googling has offered contradictory advice. On one hand stay away from cleaning w/lemon juice or vinegar, or a small amount of ammonia and baking soda with lots of warm water. This is supposed to cause the remaining porcelain to crack, introducing rust stains. Hydrogen peroxide is supposed to clean well and not introduce porcelain cracks.
Then, I have read the opposite is true.
I know to stay away from abrasive comet-type cleaners and bleach.
Any suggestions? Thanks!
LadeeDIY is offline   Reply With Quote
Old 03-25-2018, 02:34 PM   #2
Guapo
Rewards Points: 11,950
Re: Best items to clean inside of old iron clawfoot tub?
Why don't you want to use bleach? It will work wonders for you. Of course, don't use it straight & don't try to clean it all in one shot. Mix a couple ounces with water. Apply it with a sponge. Wear gloves. Do a little each day.
LadeeDIY likes this.
Guap0_ is offline   Reply With Quote
The Following User Says Thank You to Guap0_ For This Useful Post:
LadeeDIY (03-25-2018)
Old 03-25-2018, 03:16 PM   #3
Rewards Points: 136
Bleach is supposed to introduce small cracks into the porcelain and create rust stains from the cast iron. Has this worked well for you? I don't want to make a small problem worse. Thx!
Old 03-25-2018, 03:31 PM   #4
Guapo
I haven't seen a claw foot tub since the 50s in Brooklyn but we used bleach all the time on porcelain when I worked in NYC office buildings. If you want to try something else first, try toothpaste.
Pepsodent commercial: You'll wonder where the yellow went when you brush your teeth with Pepsodent.
SeniorSitizen and LadeeDIY like this.
Old 03-25-2018, 03:50 PM   #5
JUSTA MEMBER
Rewards Points: 3,578
Soft Scrub cleanser with a sponge, Worked for years when my grandmother had one, kept the ring away, and the finish smooth.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 03-25-2018, 03:52 PM   #6
Rewards Points: 1,466
We've used Gel-Scrub to clean fiberglass showers for 20 years with no ill effects. It contains Phosphoric acid. I purchase it at a janitorial supply.
I've been called a lot of things but I'm not a Guinea Pig so use at your own risk.
https://www.buckeyeinternational.com...room/gel-scrub
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 03-25-2018, 04:01 PM   #7
The cleaning agent in toothpaste is probably powered pumice. Feel the gritty. See my teeth.
Guap0_ and LadeeDIY like this.
Old 03-25-2018, 04:32 PM   #8
Rewards Points: 136
Ok, I'm calling on a bit of my friend Clorox and a lot of warm water. You guys are a lot more reliable than google searches! Thx!!
de-nagorg likes this.
Old 03-25-2018, 06:34 PM   #9
Rewards Points: 1,036
Just read an article the other day about this, it said to use Bar keepers friend, and sprinkle on a damp sink, let stand for a couple of minutes then scrub with a sponge.
Canarywood1 is offline   Reply With Quote
Tags
bathtub
inside sewer clean out slab house jeff5150 Plumbing 1 03-27-2011 07:37 PM
Clean up and paint very rusted wrought iron railing pnschi Building & Construction 4 10-25-2010 10:07 PM
Cast iron clean out COLDIRON Plumbing 11 09-12-2010 09:15 AM
Can you clean iron out of a water heater? joeblowofidaho Plumbing 1 07-03-2010 09:08 AM
Clean oil off of tools, also clean the inside of a compressor capslock Tools 1 12-23-2009 11:36 AM
