Bead Board Conditioning - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-08-2016, 06:15 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 238
Bead board conditioning
Am putting up bead board in my bathroom, and know I have to condition the boards by leaving them in the room for a couple of days before I install them. My question is do I do it before or after I paint them???
I plan on painting before installation
Barry J is offline   Reply With Quote
Old 04-08-2016, 06:39 AM   #2
Rewards Points: 1,466
Re: Bead board conditioning
Bath relatively humidity is so variable and can change from 30 % to 100 % and vise versa so fast an acclimation period would be a waste of time unless the bead board was stored outdoors. Paint, install and enjoy.
Old 04-08-2016, 09:48 AM   #3
Rewards Points: 17,890
Ever installed bead board before?
What's it going over, sheet rock?
Here's a few tips.
Look around the whole room to see how the panels are going to be effected by things like outlets, vanity, window sills, Ect.
You do not want it to end up in the middle of an outlet, I've seen that one many times.
Ideally you want to start installing it close to the middle of the wall so you have even exposure on the two ends.
All seams must end up in the middle of the studs.
If your going over sheet rock I use Loc Tite Power Grab.
http://www.loctiteproducts.com/p/12/...Heavy-Duty.htm
And go over the panel with a hand floor roller to compress out the glue behind the panel.
http://www.homedepot.com/p/MD-Buildi...8084/205352252
I use a narrow crown staple gun to attach because of the holding power and the tiny hole it makes.
Done right you should only need to nail at the butt seams because the baseboard and panel cap will hold the panels flat on the wall.
Never install it tight to the floor, leave it about 1/2" high for a couple of reasons, floors are never flat, and to stop water from wicking up the wall.
The two end pieces will need to be scribed and cut to fit for a nice tight fit so no inside corner molding is needed.
Old 04-08-2016, 08:23 PM   #4
Rewards Points: 806
At the very least prime and paint the tongues before install. With varying humidities in a bathroom you're bound to have some expansion/contraction at the seams. Much less noticeable if you've painted.
cibula11 is offline   Reply With Quote
Old 04-08-2016, 08:48 PM   #5
DIY Homeowner
Barry J's Avatar
Rewards Points: 238
The beadboard is going over sheetrock
Removing ceramic floor: tile on cement board on wood Soparklion Tiling, ceramics, marble 1 06-15-2015 11:24 AM
WAINSCOTTING With BEAD BOARD Nathan Carpentry 29 02-24-2013 03:42 PM
new furnace control board same problems? jeremptucker HVAC 4 10-20-2012 01:11 AM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 02:53 PM
cutting bead board scatterbrain General DIY Discussions 3 01-09-2008 08:13 AM
