Bay Window Trim Out - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-10-2018, 07:33 PM   #1
Rewards Points: 12
Bay Window Trim Out
I have replaced a bay window with double hungs in it, three separate windows, not one whole unit. Id like some suggestions on what I could do to trim it out. All my other windows have casing around them and wood jambs on all 4 sides. The windows were previously wrapped in drywall, no trim. The bottom (seat) of the bay window is wood and I plan on refinishing that. Im unsure how to handle the transition from drywall that remains to the new jambs that Ill be putting it. Not sure how to go about using the same casing as the other windows since there is no top and bottom casing.
Thanks.
Bay Window Trim Out-bay.jpg   Bay Window Trim Out-baytop.jpg   Bay Window Trim Out-baytop1.jpg   Bay Window Trim Out-baybottom1.jpg   Bay Window Trim Out-windowcasing.jpg
Drew63 is offline   Reply With Quote
Best Way to trim window right under soffit? lasko Roofing/Siding 2 08-25-2018 10:17 AM
Should I caulk the gap between exterior trim and window? woodsmith.ryan Roofing/Siding 8 02-10-2018 01:08 PM
Window trim over existing T-111? J Howard Remodeling 2 07-24-2012 10:49 AM
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
