Bathroom Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-29-2016, 02:36 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 238
Bathroom walls
Right now I have tile on the walls of my bathroom, all the way around, which goes up 50 in.
I want to take down the tile and put up wooden tongue and groove planks in place of the tile.
What is the easiest way to take down the tile?
Due to my hot water baseboard, should I rip out the sheet rock also, so that I can slip the planks behind the baseboard heater or cut the planks around it?
Thanks Barry
Barry J is offline   Reply With Quote
Old 03-07-2016, 07:24 PM   #2
Rewards Points: 1,036
Try a hammer and a cold chisel. You may find that the tile will pull off chunks of drywall with it, if this is the case you may want to plan on replacing the drywall anyway so you can just cut it and pull tile and drywall off together.
Mingledtrash is offline   Reply With Quote
Type of walls? (Bathroom remodel) leaf Drywall & Plaster 1 03-09-2015 11:56 AM
Code for Bathroom Walls 325_man Building & Construction 7 12-23-2014 10:34 AM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Bathroom Walls & Ceiling Outdoorbum Kitchen & Bath Remodeling 3 04-15-2013 05:19 PM
Walls and Ceiling in a new bathroom MCath Drywall & Plaster 3 03-17-2013 10:40 PM
