Bathroom Remodel South Florida - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By tryingmybest
Old 01-05-2018, 09:13 AM   #1
Rewards Points: 14
Question
bathroom remodel south florida
I am about to demo and redo an existing bathroom. Two of the walls are concrete block covered with furring strips and green board. The question is does there need to be a vapor barrier behind the green board ? And should I use some type of insulation paneling or something behind the green board. We live in south florida so i am concerned about moisture build up in this room. Haven't been able to find clarification regarding the vapor barrier. Thanks in advance
tryingmybest is offline   Reply With Quote
Old 01-05-2018, 09:25 AM   #2
retired framer
Rewards Points: 18,614
Re: bathroom remodel south florida
Vapour barrier in Florida?? Not so sure on that but you have barrier to protect the framing not so sure you need to protect the block from moisture. If you are taking down drywall you will be able to see if there has been a problem to solve. You could fill the space with foam board.
Old 01-05-2018, 09:56 AM   #3
Rewards Points: 14
thanks for the quick response . that sounds like a plan. the people who did this previously could make a what not to do show so trying to do it right this time
Nealtw likes this.
Tags
bathroom remodel , drywall , vapor barrier
Master Bathroom Remodel, question with pictures! PolySuperman Kitchen & Bath Remodeling 4 06-17-2014 10:46 AM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Newbie with bathroom remodel pierrekitty Remodeling 20 03-10-2011 04:22 AM
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 07:28 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
