Bathroom Into Closet Space & Cove Ceilings - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-05-2015, 07:05 PM
Rewards Points: 117
Bathroom into Closet Space & Cove Ceilings
Looking to give up a bedroom closet to add a second bathroom to our home. The closet space is a bit small, so I'm looking to extend 2 feet into the bedroom space, then adjacent to that add a 2'x4' closet, so the face of the closet and bathroom are flush (see floor plan). I'm a homeowner and not much of a carpenter so I'm looking to hire trades. Plumber says a bit tricky but 'can do' using a wall-hung toilet to save space. Trouble is, so far, the experienced carpenters I've interviewed all seem to balk at the job. Several have said I should make use of the existing closet space, but even if I could squeeze a sink and toilet into a 35x56" interior space (leaving only 14" between knees and sink), I'd still have to move the closet door to create better access between the sink and toilet. Furthermore, the wall-hung toilet would be on an exterior wall, which is not wise in cold climates (and voids thee warranty).
The other issue is that we have coved ceilings, which no one seems to want to touch. In spite of this, why is it so confounding for carpenters to construct a built-in closet? True, I could probably buy an Ikea/ready-made closet for much less cost, but it doesn't take storage advantage of the full ceiling height, nor the most optimal width to suit the space. I keep thinking I just haven't found the right carpenter, but their consistent doubts have me doubting myself!?! Any thoughts? Comments on my floor plan? I know it's a bit tight between the bed and the closet/bathroom, but if I make the bathroom shorter then the closet loses depth and 23.5" is minimum depth for good closet space--as far as I know. The attached photos show the style of coves in our home.
Bathroom into Closet Space & Cove Ceilings-img_1959.jpg   Bathroom into Closet Space & Cove Ceilings-img_1960.jpg   Bathroom into Closet Space & Cove Ceilings-img_1962.jpg   Bathroom into Closet Space & Cove Ceilings-new-powder-room-closet.jpg
akimbo is offline
Old 07-11-2015, 03:04 PM
Rewards Points: 5,348
I'm pretty sure I've seen foam forms around for use on ceilings so you could match existing profiles. You could probably make the yourself if need be. Plywood template and bendable 1/4"sheetrock or profile rigid blocks and compound the surface.
Many contractors shy away from one offs. Not familiar and don't want to learn.
Why a 1/2 bath in a bedroom?
Ron
B. Franklin 1759
Ron6519 is offline
Old 07-11-2015, 04:16 PM
Rewards Points: 117
Thanks for your thoughts Ron. Yes, I've seen cove kits for sale to use with bent sheetrock so I don't understand why cove repair is so scary. Looks like I'll be doing that part myself. As to why a 1/2 bath: no room for more. I'm using a closet space and stealing an extra 2 feet from bedroom to make a 4x5' powder room.
akimbo is offline
Old 07-16-2015, 07:48 AM
Rewards Points: 6
It's really quite tough job to do for carpenters .Go for an experienced one which will guide you to do the work based on your requirements .
donaldgolson is offline
Old 07-17-2015, 01:10 AM
Rewards Points: 117
Thanks donaldgolson, I understand that the coves may be scary, but why so hesitant about the framing?
akimbo is offline
Does bathroom fan vent duct need insulation when in a heated space? Studly Remodeling 8 04-04-2014 11:30 PM
Converting Vented Crawl Space to Unvented/Conditioned Achille76 Building & Construction 4 02-19-2013 09:10 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
making use of space in high ceilings manhat Interior Decorating 4 07-15-2011 12:48 AM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
