Bathroom Fan Questions - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-08-2014, 04:20 PM   #1
Rewards Points: 54
Bathroom fan questions
Hello,
I currently have a combined bathroom and laundry room. I want to add a partition wall dividing the two rooms from one another. The problem is, there is only one fan located on the ceiling right where I want to install the wall. Does anyone have any advise as to how I can redirect the fan into one or both rooms?
This leads me to my next question. Do I need a fan in the laundry room? Could I just add a new fan in the bathroom and direct it with duct work to the vent leading outside or should I add duct work splitting fans in both rooms to the outside? Is it even possible to direct fans with duct work?
Thanks a lot.
eagle3ye is offline   Reply With Quote
Old 06-08-2014, 05:14 PM   #2
Rewards Points: 582
remove fan from center where wall is going and reinstall in just bathroom...not that big of a deal...
Old 06-08-2014, 05:28 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
Originally Posted by eagle3ye View Post
Hello,
Thanks a lot.
They make fans that the fan sits higher from the ceiling and just the ducts attach to the ceiling. You could run one duct to each room using a wye.
Just to answer your question. Is it even possible to direct fans with duct work?
Robpo is offline   Reply With Quote
Basement bathroom DWV questions. Vwovw Remodeling 0 10-22-2013 12:34 AM
Small Bathroom remodel questions and step order Velvis Kitchen & Bath Remodeling 0 04-26-2012 04:36 PM
Plumbing Questions - Convert Upstairs Laundry Room to Bathroom mjp24coho Plumbing 3 01-02-2012 11:16 AM
Basement Bathroom Rough In Questions Mike Fox Plumbing 10 11-10-2011 08:35 AM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
