Bath Tub In Basement - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By 195795
Old 02-02-2019, 11:53 AM   #1
Solutions (handyman)
Rewards Points: 492
Bath tub in basement
A client on mine wants a bath tub in their basement. I think I need to build an elevated floor to be above the concrete level, and the question is, how much clearance do I need to run a proper drain. I'll need to run from the tub drain down and about three feet to connect to an existing drain.
My primary question has to do with the under side of the tub to allow for connections and a proper slope.
Mark Harvey is offline   Reply With Quote
Old 02-02-2019, 12:25 PM   #2
retired framer
Rewards Points: 17,298
Re: Bath tub in basement
If the rest of the plumbing is there, tap the floor with a hammer and you may find a spot about a foot square where the concrete is about one inch thick and there is a chunk of foam hiding the pipe in the hole and it may have the trap already installed.
Old 02-02-2019, 04:47 PM   #3
Rewards Points: 1,272
Don't build a platform, open the concrete instead; that's really the right way to do it.
mark sr likes this.
195795 is offline   Reply With Quote
Old 02-03-2019, 06:34 AM   #4
Rewards Points: 6,358
Save yourself head ache, money, and time.
ron45 is offline   Reply With Quote
Old 02-03-2019, 08:28 AM   #5
Rewards Points: 8,897
Shop around and read the MFG literature. The last two tubs I installed were staged high enough that the floor only needed to be cut at the point where the down drop started. I cut it larger for the option of replacing the drain from below if ever required but that isn't an option in a basement floor.
I completely agree with Neal and Texas.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Thinking about adding a half bath in basement stradt03 Plumbing 13 05-22-2013 09:54 AM
2nd floor powder room directly over exist. basement full bath baltimorecaesar Plumbing 0 07-16-2012 09:39 AM
Basement 1/2 bath install Jimmy Manfredi Plumbing 9 02-05-2012 04:08 PM
Venting a new bath in basement jerryls Plumbing 9 03-04-2011 09:24 AM
