Basement Wall Fix - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-06-2015, 09:36 PM   #1
Rewards Points: 4
Basement wall fix
Hey everyone. I've got an old house and one corner of my basement wall leaks when there is any amount of rain. I've done everything I could on the outside to keep water away but still can't stop it. I have tried hydraulic cement and it helped at first it helped but the water found its way in. Any suggestions that won't cost thousands of dollars. Thanks!
bickett34 is offline   Reply With Quote
Old 05-13-2015, 08:06 AM   #2
Rewards Points: 2,472
That is a problem that will cost some money to fix. If regrading and channeling the rain away did not help, it needs something like a french drain to catch the water and pump it away from the house.
The window suggests that corner is not under a lot of earth and its pressures. That means the settling of the foundation/footing was uneven and the blocks moved.
If you can't repair it, and settling may not have stopped, I'd leave it open. By the way, outside photo will help.
carpdad is offline   Reply With Quote
Basement floor leaking after wall repair unfortunateluck Building & Construction 6 02-15-2011 06:05 PM
vapor barrier on basement pony wall hobbs in vanvouver Building & Construction 3 02-13-2011 08:07 AM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 08:39 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Leaking Basement Wall MStocks Building & Construction 3 10-29-2009 09:57 PM
