Basement Remodel - Loud Noise - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-03-2016, 05:03 PM   #1
Basement remodel - loud noise
OK I may have made a mistake in my remodel. We just got the drywall up and wow what a difference, looks awesome, but that really magnified the sound from upstairs. I never noticed it before while being down there. It is not finished yet so I may have some options.
Is batting or blow in better at this time? the way it is all set up I could pull down about 5 sheets off the center 3 on one side and 2 on the other side. This might allow me to push or slide batting about 6-8 feet. I may not be able to reach it all with the HVAC in some of the cavities but I could get maybe 80%.
Any ideas? Will this help dampen the sound. I know I can not eliminate it. What would be best to use for the batting? is there a specific type? or should I use the blow in and rent a machine. Just a mess if I ever need to pull it down.
Any advice would be appreciated....
tandrle is offline   Reply With Quote
Old 03-03-2016, 05:14 PM   #2
Rewards Points: 17,890
Little late now to do anything.
http://www.soundproofingcompany.com/...oof-a-ceiling/
Mingledtrash (03-04-2016)
Old 03-03-2016, 05:28 PM   #3
is it?
I know I can not eliminate it but if I was able to get some batting up in there will it help or am I wasting effort?
Old 03-04-2016, 04:58 PM   #4
Rewards Points: 1,036
Check out the link joe provided choose which option works best for your situation.
another thing you can check out is glue-on acoustic ceiling tile
Mingledtrash is offline   Reply With Quote
Old 03-06-2016, 09:13 AM   #5
Rewards Points: 2,458
Sound is a wave of energy. You can slow it down with air (empty), block with dense material or make it bounce away from you. Fiberglass is cheap and does a fair job, but it must be installed properly and fluffy. Stuff it and you are wasting your money. Dense insulation like rockwool does even better job and again you can't stuff it, they must be placed.
If sheetrock is all you have to replace, remove it, and do it again.
carpdad is offline   Reply With Quote
Basement Remodel Crash_Davis Project Showcase 19 04-22-2016 08:38 AM
2013+ - Basement Remodel Geran Brown Project Showcase 16 07-19-2014 08:46 AM
Remodel enigma with basement Daugela Building & Construction 36 05-21-2013 12:22 PM
Basement wall insulation / remodel question Chokingdogs Insulation 2 03-14-2013 12:26 AM
Basement remodel Badfish740 Project Showcase 4 06-08-2012 06:31 PM
