Basement Lighting - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-08-2016, 09:53 PM   #1
Rewards Points: 2
Basement lighting
Can post a picture later if it is hard to understand, but I'm sure everyone will get this problem.
Just bought a new house with a partially finished basement. It has a fixed ceili with 3 lights. One of the lights turns on and off by a switch at the basement entrance (top of stairs). The other two lights are old pull string.
I want to put some LED recessed lights in, but I want them all to be attached to the light switch. So how can I connect all of them if the ceiling is already fixed?
Trying to figure it out, but guessing I will have to tear down a lot of the ceiling to run the wiring and install the new lights
Psl1122000 is offline   Reply With Quote
Old 01-08-2016, 10:09 PM   #2
griz's Avatar
Rewards Points: 572
An Electrician may be able to fish wires to eliminate or minimize repair to the ceiling.
It's nothing you can be taught here.
Not DIY stuff.
griz is offline   Reply With Quote
The Following User Says Thank You to griz For This Useful Post:
Psl1122000 (01-08-2016)
Old 01-08-2016, 10:58 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,516
You will need to fish cable to the existing fixture and tie in there. it may involve making some holes in the existing ceiling.
Prep to finish basement...Sub Panel? Thisgrub4u Electrical 14 01-06-2014 11:10 PM
Recessed lighting in basement - thoughts on layout sheffdave2002 Remodeling 15 11-20-2012 09:49 PM
Installing basement recessed lighting jdtox Electrical 13 05-06-2012 09:44 AM
Lighting in Basement nhoj Electrical 14 02-25-2012 03:51 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
