Basement Insulation For Townhouse - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-02-2015, 10:06 AM   #1
Rewards Points: 2
Basement insulation for townhouse
New to chat room
For economical reason I want to insulate the ceiling and only cinder block walls necessary not to include 2 common walls.
What insulation materials to sound proof ceiling and to insulate the other 2 walls?? Can I do this by myself or enlist help?
Luisa
Luisa is offline   Reply With Quote
Old 03-03-2015, 08:30 AM   #2
Rewards Points: 2,490
Regular r-13 fiber in ceiling gives most economy. Then cover with 1/2" sheetrock.
Use 1 1/2" blue foam board on foundation walls, cover all exposed concrete, can spray foam for all joints except the bottom if you need drainage. Use verticle beads of foam construction glue and quick setting glue on 4 corners. 3/4" ply under the floor joist as fire stop, furring strips directly on insulation with tapcon, paperless sheetrock, then electric outside. That is way I did it. You can frame with metal or 2x for space to put the electrics, etc, inside the wall.
carpdad is offline   Reply With Quote
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
