Basement Framing/Sheetrock In NJ - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-23-2013, 11:53 AM   #1
Rewards Points: 12
Basement Framing/Sheetrock in NJ
My basement is 99% dry - once in ten years the outside downspout over flowed and I could see moisture marks a few inches down the walls but never on the floor or puddling.
When framing and prior to sheetrock:
Do I need to use a vapor barrier?
Do I need to use green/moisture resistant sheetrock?
slamseven is offline   Reply With Quote
Old 11-24-2013, 07:00 PM   #2
Registered User
Rewards Points: 526
I wouldn't use either; http://www.diychatroom.com/search.php?searchid=4327189
Gary
Insulation in basement ceiling for soundproofing -- will basement be too cold? jmai14 HVAC 3 11-16-2013 10:04 AM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
