Basement Framing - 2x2 Or 2x4's? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By JazMan
Old 11-25-2016, 10:22 AM   #1
Rewards Points: 14
Basement Framing - 2x2 or 2x4's?
Long story short. My basement flooded a couple of years ago. I took care of the outside sloping, gutters, downspouts, as well as sealed the interior. Have not had a drop of water in 2 years. Going back a couple of years ago, the basement walls were sectioned off by a ledge of wood at about 42 inches of height. Anything above that height was drywall which is fine. Anything below the ledge was removed, which included 2x2 furring strips glued to the wall and sheets of 30 year old laminate wood.
Flooring has been layed down to make the space usable (Dricore and then laminate wood). The lower half of the wall is currently just concrete. I do not have any electrical boxes or plumbing to deal with on this lower half of the basement wall. My plan is to put drywall on this lower half. Any issue with putting either a 2x2 or 2x4 (pressure treaded) and screwed to the wall at 16" intervals?
pauly99 is offline   Reply With Quote
Old 11-25-2016, 01:50 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 748
Re: Basement Framing - 2x2 or 2x4's?
You're not supposed to use PT lumber indoors unless you can find kiln dried PT, which I doubt you will. Kiln dried #2 is what you want, even stud grade will be ok in this case.
Are you sure you wanna stay with no electrical outlets on those walls? Obviously no permits when this was done. Could be a problem some day.
Jaz
joecaption likes this.
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 11-25-2016, 01:53 PM   #3
Rewards Points: 14
I will look for Kiln dried #2 then.
All of the electrical is up top. So above the ledge with the good drywall, I must have about 8 outlets going around the basement.
Old 11-25-2016, 04:45 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 748
Forgot to say I think 2x2 will be fine, or why not 1x2 with appropriate shorter screws for the wallboard. I take it none of these walls are outside walls just partitions.
Jaz
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Finishing Basement - Framing with 2x2's mark2741 Building & Construction 13 12-25-2011 07:20 PM
Basement Framing ddave23 Building & Construction 4 10-30-2011 10:38 AM
which method of framing and insulating basement daphillenium Insulation 3 10-27-2011 08:27 AM
Basement Stair Framing clemson726 Building & Construction 4 07-26-2010 05:09 PM
