Basement Framing - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-03-2013, 03:07 PM   #1
Rewards Points: 71
Basement framing
Am trying to attach my pressure treated plates to basement concrete floor using a hammershot powder fastening system. The charges are .22 calibre level 2 as the concrete floor is under 5 years old.
The problem is that the nail barely goes into the wood with the charge. Only about 1/4 inch deep. I understood that these should shoot the nail through the wood and a full inch into concrete. Any ideas as to what Im doing wrong?
Thank you
RichTibo is offline   Reply With Quote
Old 11-03-2013, 03:14 PM   #2
Rewards Points: 17,884
If your hitting it hard enough to fire the shot then your doing it right.
Going to have to go to a higher shot.
Still not work then go with a hammer drill and use Tap-Cons.
gregzoll (11-22-2013)
Old 11-04-2013, 09:30 PM   #3
Registered User
Rewards Points: 526
Slip some foam board under the plate (non-pt, check locally) with a continuous bead of caulking against the concrete floor for an air/thermal/capillary break to the cold slab/earth below to protect the studs/cavity insulation; http://www.greenbuildingadvisor.com/...-building-code
Gary
Old 11-20-2013, 09:40 AM   #4
Rewards Points: 1,602
I've used .22's multiple times with pt wood with no issues. Are you holding the gun firmly to the wood? Are you hitting a knot? Knots shouldn't make a difference, but I can't think I've any reason why it wouldn't go through the wood.
What nails are you using?
mikegp is offline   Reply With Quote
Old 11-22-2013, 09:42 AM   #5
Dark Knight
Streeter1981's Avatar
Rewards Points: 18
Send a message via AIM to Streeter1981
I have used Tap-Con concrete anchor screws in the past for basement base plate anchoring along with the hammer drill, but honestly they were kind of a pain.
A construction-foreman neighbor of mine gave me some of these Concrete wedge anchors and they are awesome!! I had two more base plates to do when he gave me those, and I wish he had told me about them earlier!
You just drill the hole with a hammer drill, then you hammer the anchor in the hole (easy) and turn the nut with a ratchet or wrench to create the wedge. And it's WAY in there, and WAY easier than screwing in Tap-Cons in my opinion.
Streeter1981 is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Basement Framing Help Captivating Remodeling 4 07-16-2012 07:19 PM
basement framing / insulation question in storage portion of finished basement. cobra5laddict Insulation 5 03-22-2012 09:59 PM
Basement framing: PT wood? ChrisWz Remodeling 9 02-23-2012 11:09 PM
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 12:06 AM
