Basement Floor Obstructions Ideas - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-13-2017, 01:28 PM   #1
Rewards Points: 2
Hi,
I just got new drain tile in the basement, and they installed "clean outs" about 1' from the block wall. They stick up about 1-2" from the floor. I also have a sewer clean out along the same wall that sticks up about an inch. I was wondering if anyone has any ideas to hide these when I put flooring in? Right now the only idea I have is to hide them under furniture.
Thanks!
sobiesk2 is offline   Reply With Quote
Old 02-13-2017, 02:45 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,312
Re: Basement Floor Obstructions Ideas
Small bulkheads on the walls with some base molding trim going around them and a lift off top.
Old 02-14-2017, 07:31 AM   #3
Rewards Points: 2,472
I cut the cast iron flush to the slab and put a expanding rubber washer plug in it. The metal plug sat on the pipe, although your case may be different. The top was recessed for bolt so I cut the protruding bolt as well. Cut with the bolt on and smooth out the bolt so that the nut comes off. I used 4" diamond cut blade on a grinder. The plug may have come with the wing nut but I'm sure it ended up with a regular hex nut.
carpdad is offline   Reply With Quote
Basement Ceiling Ideas. deafanddiabetic Building & Construction 14 10-18-2016 04:32 PM
Ideas for painting or covering Foil Faced Insulation in basement Scamp7144 General DIY Discussions 2 10-18-2016 06:14 AM
Basement air circulation systems ideas phantomvs HVAC 5 01-29-2016 02:44 PM
Ideas For Basement Bathroom Remodel DrHicks Kitchen & Bath Remodeling 8 01-21-2011 03:53 PM
Basement Design Ideas bphyatt Building & Construction 5 12-09-2009 10:39 AM
