Basement And Finishing - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-09-2016, 11:41 AM   #1
Rewards Points: 78
Basement and Finishing
Hi all,
I have been researching for a few years now on finishing my basement. I have run a few main power wires to specific locations, but next on the list is to start framing. This is where my issue comes into play. We all have the HVAC system to deal with, but my returns, and pics below, are essentially, framed in with the joists. Unless they just did that to keep the return air in a pipe? I ask as I need to run a wall in the same direction as the joists, but the returns are in the way. My only thought is to add a 2x4 to the joist so that I can attach the metal framing to it. Thoughts? Suggestions?
Thanks!
rkovelman is offline   Reply With Quote
Old 10-09-2016, 11:45 AM   #2
Rewards Points: 78
Re: Basement and Finishing
url=https://postimg.org/image/f2eakhv0r/][/url]
Old 10-10-2016, 03:44 AM   #3
An old Tradesmen
Rewards Points: 7,732
Your returns are joist panned. No pipe inside.
Old 10-10-2016, 09:44 AM   #4
Rewards Points: 4,104
You'll create a soffit around this. Some call it a bulkhead.
stick\shift is offline   Reply With Quote
Old 10-10-2016, 05:45 PM   #5
Rewards Points: 78
Thanks guys! Not sure if this a good or bad thing, but probably a different discussion for another day.
I would think of building a soffit around all of it, but I am going to do a drop ceiling. I guess my issue is that I want to build a wall in line with the return. Do I just add 2x4 to the beam that the returns are attached to? I am trying to figure out how I can attach the metal studs to it? I am also not sure if it is illegal to not allow access to the return/cover it up with wood.
Old 10-10-2016, 06:52 PM   #6
An old Tradesmen
Fasten the plate directly to the joist as you would if the return wasn't panned. No code requiring access to the return.
The Following User Says Thank You to beenthere For This Useful Post:
rkovelman (10-10-2016)
Old 10-10-2016, 09:24 PM   #7
Rewards Points: 78
Wow good to know. I will probably seal up all the joints prior to make it airtight. It wouldnt be wise to try and do that after all the walls are done.
New Basement Finishing Project Part 1 RKBA Remodeling 5 07-11-2015 06:09 PM
Basement Finishing Plan phoray Remodeling 3 12-20-2013 01:14 PM
Advice on finishing my basement? jakec202 Remodeling 1 07-06-2012 03:11 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
