Basement Finish - Soffit Against Poured Concrete - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 09:07 AM   #16
Originally Posted by cortell View Post
Your picture lacks 2x4s running from the ledger to the left corner of the bulkhead. Those provide a nailing surface for the top plate of your wall. Your top plate will not be nailed to the ledger,
OH YEAH!! I knew that!!!
haha.. thanks.. what was I thinking!!!!????
InDashMP3 is offline   Reply With Quote
Old 04-10-2012, 09:18 AM   #17
cortell's Avatar
Rewards Points: 504
This made me realize that the ledger has further responsibility beyond holding up half the weight of the narrow strip of sheetrock and cross studs. It also needs to keep the studded wall in place. This would lean me away from studding over the foam board. I'd want a pretty tight anchor connection, and I suspect that would not be good for the foam board. But I'd check with the manufacturer all the same.
cortell is offline   Reply With Quote
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 08:33 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Laminated flooring over basement concrete Woodcutter Flooring 2 10-25-2011 08:55 AM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 06:27 PM
Basement Finish with Projector and Media Cabinet C_J_GO Project Showcase 8 08-15-2009 10:35 PM
