Basement Finish - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 11-20-2017, 09:48 AM   #16
VAer's Avatar
Rewards Points: 1,548
Re: Basement Finish
I am not sure if it is common to have open space basement, as the red photo suggested by contractor.
Any suggestions?
VAer is offline   Reply With Quote
Old 11-20-2017, 09:52 AM   #17
retired framer
Rewards Points: 18,692
Re: Basement Finish
As long as you don't remove the post or posts you can open it all up.
You can raise the ceiling but you will still have drops to hide the havc ducts.
The normal is the have a wall beside those drops as having drops thru the middle of the room looks dumb. When we have that we are more apt to drop the whole ceiling.
But all that sound like what you have now. There are no standard layouts.
Old 11-20-2017, 09:56 AM   #18
VAer's Avatar
Re: Basement Finish
Thanks for the comment, yes, there will be drops to hide HVAC/black metal cuboid. I understand there are no standard layouts, but I am concerning if I go with an unpopular layout, it will affect sale value in the future.
If I go with green photo (my own design, not removing wall, adding a wall for storage room), how to take care of floor drain (which will stay inside storage room)?
Green photo: I look at basement over again, I think the storage wall will be right ON the floor drain, maybe I should push the wall to the left a little bit (make storage room a little smaller, keep floor drain in utility/laundry room)?
Old 11-20-2017, 10:11 AM   #19
retired framer
Re: Basement Finish
Try this. Extend the wall with door all the way across.
Make a short hall way at the bottom of the stairs with a doors on the left into utility room and theater. Door at the end of the hall to store room on right and if you divide that room on the right into two room another door on the right.
Part of the far end of the utility room can be used for a sound room, all the electronic gear for the theater.
If you plan on wood working down there later, close heat and return ducts in the room and put a sweep on the door to control dust. Need another heat source.
Old 11-20-2017, 10:17 AM   #20
retired framer
Re: Basement Finish
Our newer houses only have a drain near the water tank to catch a problem with the tank. The drain is hooked to sewer withe a dribble valve that adds water to the trap. I would not worry about the drain for the utility room and leave the drain where it is. I am thinking the theater would work best in that corner.
Old 11-20-2017, 10:21 AM   #21
VAer's Avatar
Re: Basement Finish
Do you mean like this attached photo? I have issue with it, I don't want to have movie room(or maybe entertainment room in the future) becoming smaller. It is waste to have big storage room.
Old 11-20-2017, 10:28 AM   #22
VAer's Avatar
Re: Basement Finish
Actually, if goes with red photo (contractor's proposal), there is only 15 feet length of drops, is it something tolerable?
Old 11-20-2017, 10:33 AM   #23
retired framer
Re: Basement Finish
Well you might want to consider the fit finish and furniture for the theater. The bigger it gets the more expensive to finish. You would not want that to look like a big empty room with a bit of nice.. I would make the utility room a little wider so you had two doors off the hallway.
Old 11-20-2017, 10:35 AM   #24
retired framer
Re: Basement Finish
Some people seem not to care about the drops and other people go nuts with design around the room to make it all look balanced.
Old 11-20-2017, 10:45 AM   #25
VAer's Avatar
Re: Basement Finish
It is unlikely not to have drop, for my case, even if there is no HVAC ducts, there will still be drop for black metal cuboid to support weight. For other basements, if it is open space, there should be something in the middle to support the weight, correct?
In my case, the drop is too obvious, since the drop covers HVAC ducts too.
Old 11-20-2017, 10:52 AM   #26
VAer's Avatar
Re: Basement Finish
Let me ask this way: if I remove interior wall, if in a few years the house is on the market for sale, and if potential buyer does not like the layout, how much will it cost to add the wall back there?
Is it easy to add a wall in the future and revert back to current layout?
Old 11-20-2017, 11:10 AM   #27
retired framer
Re: Basement Finish
Adding and moving interior walls is not a big deal and the way things are today when everyone wants to remove walls, I doubt not much of what you do will diminish the value. Even for that what people need, just like yourself is information on what is there. So leaving drawings and pictures for potential buyers can be helpful for others to see if their plan will work.
Mostly what you want is for your design to make some sense. Room sizes that will work for office space or something,Outlets ever 12 ft and light switches in the right location to the doors. If you don't have big enough windows don't put in what would look like bedroom closets.
Old 11-20-2017, 11:27 AM   #28
VAer's Avatar
Re: Basement Finish
Thanks. I am trying hard to convincing myself to accept contractor's proposal to remove interior wall. Actually, I have never thought of such plan before he told me so.
Nealtw likes this.
Old 11-21-2017, 10:53 PM   #29
VAer's Avatar
Re: Basement Finish
Where to put dryer/washer/sink in utility/laundry room? Sink in the corner or middle against wall?
Thanks.
Old 11-21-2017, 11:11 PM   #30
retired framer
Re: Basement Finish
Don't forget to include the post in the drawing, uou won't be removing it.
Basement Finish HVAC Plan Review BaconK5 HVAC 2 11-03-2014 08:35 AM
Prep to finish basement...Sub Panel? Thisgrub4u Electrical 14 01-06-2014 11:10 PM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 07:28 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Want to finish basement mopared Remodeling 3 02-20-2005 04:49 AM
