Basement Door Near Stairs Landing - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 12-02-2018, 08:00 PM   #1
Rewards Points: 14
Basement door near stairs landing
So I want to put a 36 inch door at the bottom of my stairs. There is currently a 12 inch high landing at the bottom of these stairs and then you turn right to get into the basement. The problem is the distance between the landing plywood and the top of the framing is only 76 & 1/2 inches. I would need to put 2x 2/4's at the top of the framing so I can put the door molding on and the top of the ceiling can be dry-walled so that only gives me 73.5 inches. I am 6'1 and I don't want to duck under this door every time i come down into my basement so I am looking for options.
I created a 2-3 min video demo. Please watch it as it explains everything. I am also attaching pictures to this thread.
https://streamable.com/6ulkl
The three options I can think of are as follows.
- Cut the door to 73.5 inches and just have a short door and people duck coming down the stairs
- Cut out the landing and lower it 8.5 inches so we can have a full frame for 82 inches to put in a 36x80 door.
- Rebuild the stairs with steeper steps so we can remove the landing completely and the stairs touch the basement floor.
Any other ideas or options? I am a pretty good DIY'er.
Basement door near stairs landing-20181202_202421.jpg   Basement door near stairs landing-20181202_202424.jpg   Basement door near stairs landing-20181202_202429.jpg   Basement door near stairs landing-20181202_202434.jpg   Basement door near stairs landing-20181202_202441.jpg
JonEhh is offline   Reply With Quote
Old 12-02-2018, 08:01 PM   #2
Rewards Points: 14
Re: Basement door near stairs landing
Here is a link to the video.
195795 and Nealtw like this.
Old 12-07-2018, 09:41 PM   #3
Rewards Points: 14
Anyone anymore suggestions?
Old 12-08-2018, 12:15 AM   #4
retired framer
Rewards Points: 18,432
You are up against it, You can't get to the min. required height at the nose of the landing and usually there are changes to the floor framing above that can be made but you have trusses hanging from a beam.
Can you measure the total distance from the floor nose upstairs to the end wall?
draw a level line from the floor up stairs over to the wall above the landing and measure down to the concrete floor.
It doesn't look like you could re work the stairs but doing the math is cheap.
Old 12-08-2018, 12:24 AM   #5
retired framer
lenaitch likes this.
Old 12-08-2018, 12:29 AM   #6
retired framer
If you cut away half of your landing like the picture on the right above. and build a new wedge shaped landing at 6" high extending that landing out about 12 inches past the door I think you will find that reasonably comfortable. And it will be code almost.
Old 12-08-2018, 09:00 AM   #7
Rewards Points: 1,272
1. Why door at all ?
2. Why door at bottom ? Is there one at top of stairs ? If not, possible ?
3. If no door at top, just build out a little foyer at bottom and put door in that foyer instead of at that landing - looks like you have the space to do so.
195795 is offline   Reply With Quote
Old 12-08-2018, 10:50 AM   #8
retired framer
As is he doesn't have 80" head room.
Old 12-08-2018, 02:09 PM   #9
For the little foyer option, sure he does - he said it's 76.5" from top (underside of ceiling joists) to the plywood on landing, and that landing is easily another 6" right.
Old 12-08-2018, 02:13 PM   #10
retired framer
Sure he does - he said it's 76.5 from top (underside of ceiling joists) to the plywood on landing, and that landing is easily another 6" right.
You measure from the nose of the stair or landing to the obstruction so he has 76"
Old 12-08-2018, 04:05 PM   #11
I know - I'm saying add a little foyer in the basement itself - so add the step(s) to the landing to get you onto the actual basement floor and once in the actual basement, frame out a little foyer and in that framing add a standard pre-hung door - the bottom of the door is an inch or so above the actual finished basement floor.
Old 12-08-2018, 04:19 PM   #12
retired framer
Yes that I understood but the landing is too high, The pie second bottom step is the best he gets and if he expands the bottom one out into the room he can cheat the pie wedge to a more comfortable one.
I know he won't be happy because he just built that landing but he should remove it and build a new one at the lower level and then play with the shape of the wedge on top of it.
Old 12-08-2018, 04:40 PM   #13
Just watched the video again and see you do have a door at top of stairs - so why a door at the bottom ?
I don't have a door at the top or bottom of stairs going down to my finished basement - no worries.
Old 12-08-2018, 04:45 PM   #14
The height of the landing is not an issue for him, 76.5" is plenty of headroom, even for him at 6'1" (73") - he is concerned about a door there. I'm saying forget putting the door there (actually I say no door down there at all), put it in the basement itself in a little added foyer area.
PS - not crazy about the tile on the landing, that's a slip and fall (and lawsuit) waiting to happen.
Old 12-08-2018, 05:20 PM   #15
retired framer
I got that, 80" is still min height.
New basement staircase with landing veeps Carpentry 8 11-20-2017 07:30 PM
Stairs WillK Building & Construction 13 09-01-2015 08:09 PM
How to finish basement stairs mark2741 Flooring 9 11-13-2012 12:09 AM
Basement egress stairs June Benninger Building & Construction 0 08-07-2010 01:54 AM
Water leaking down outside concrete basement stairs handlethis Building & Construction 3 08-06-2010 03:49 PM
