Basement Ceiling Ideas Needed - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-10-2014, 10:41 AM   #1
Rewards Points: 31
Basement ceiling ideas needed
Need to replace or improve my basement ceiling. Currently tongue and groove acoustic tile, made of particle board (for lack of a better term). They're dis colored from age and the previous owners smoking habit, and broken or missing from the times we had to get into the ceiling for other projects.
Replacing with a hanging drop ceiling is the most obvious way to go, but is there anything more cost effective? What about a glue and stick ceiling tile?
Pics are attached. Any ideas?
jmorc2003 is offline   Reply With Quote
Old 11-10-2014, 12:26 PM   #2
Rewards Points: 17,882
Anything glue and stick is never going to work.
I've just gone over it with 1/2 light weigh dry wall using both 2" screws and drywall adhesive.
Renting a drywall lift makes it an easy job.
Old 11-10-2014, 07:47 PM   #3
Rewards Points: 270
Cost effective would be replacing damaged tiles,and painting the whole ceiling.
flhtcu is offline   Reply With Quote
Old 11-10-2014, 10:10 PM   #4
Davejss's Avatar
Rewards Points: 894
I recently did a basement ceiling using white solid soffit panels. We used the triple 4" panels from Mastic. Ran a J-channel around the perimeter and installed just as we would do a porch ceiling. It's bright, clean, easy to install, and easy to remove if ever the need arises. The client likes it so much that I'm contracted to do the same for his two buddies.
Davejss is offline   Reply With Quote
basement ceilings Ideas Needed Kmikrot Remodeling 7 10-01-2012 09:45 AM
Obnoxiously low basement ceiling height....Finishing basement. bustedstuff88 Remodeling 19 08-23-2012 09:04 PM
unfinished basement ceiling questions Amateuralex Remodeling 8 07-21-2012 06:59 AM
Sound Deadening Basement Ceiling darrylshill Drywall & Plaster 4 06-01-2012 06:01 PM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
