Backsplash Tile Adhesive - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By chandler48
Old 07-26-2017, 06:40 PM   #1
Backsplash tile adhesive
I have to add just 3 pieces of bullnose tile to a backsplash what is the easiest way to do this? Can I just silicone them to the wall? Also, I have the sanded grout on the backsplash would it be ok to use the caulk version of that color around the bullnose?
Tgiambattista is offline   Reply With Quote
Old 07-26-2017, 06:42 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,652
Re: Backsplash tile adhesive
What did you use on the field of the tile? Thinset, Acrylpro, etc.?? Use the same thing you used in the field, and no, use the proper grout. You are approaching the end of a project. No need to cheap out, now.
Mike Milam and Nealtw like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
New Inside Wall - Over Ceramic Tile - Need Adhesive HTFreak Building & Construction 0 06-01-2015 03:24 PM
Remove old Tile adhesive before laying Underlayment? wvphysics Flooring 8 03-20-2015 01:31 PM
Construction adhesive behind stainless steel backsplash a must??? mudworm Building & Construction 6 12-08-2014 02:43 AM
best adhesive for marble tile mural backsplash linda lou Tiling, ceramics, marble 2 08-12-2012 07:39 AM
18x18 Tile backsplash mumof5 Remodeling 3 06-10-2012 07:10 PM
