Backsplash Behind Bathroom Sink - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-03-2018, 12:24 AM   #1
Rewards Points: 36
Backsplash behind bathroom sink
Hello,
Is it a good idea to have a backsplash for waterproofing behind a half-bathroom sink, or is there something to make drywall more waterproof (sealant)?
I know they make 'green' drywall sheets, but would this be sufficient?
Mike410 is offline   Reply With Quote
Old 09-03-2018, 04:46 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,604
Re: Backsplash behind bathroom sink
Backsplashes make for good splash protection and cleaning. Greenboard is more water resistant than standard drywall, but if you prime and apply a good paint to regular drywall, you should achieve the same protection.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-03-2018, 05:26 AM   #3
retired painter
Rewards Points: 1,342
Specifically a latex enamel [any sheen] they do a better job of repelling moisture than flat paints do. Regular drywall paints better than greenboard.
Doesn't your countertop have a short backsplash?
mark sr is online now   Reply With Quote
Old 09-06-2018, 04:37 PM   #4
Rewards Points: 36
Thanks for the replies, I still need to do some thinking on the setup for the small half bathroom. The current bathroom has tiles from the floor up to behind the sink. It's good to know paint adds some moisture resistance.
Old 09-06-2018, 05:18 PM   #5
Rewards Points: 4,150
To me a back splash just makes it look better.
The added bonus is it helps with the splashing water.
ron45 is online now   Reply With Quote
Bathroom sink/utility sink sharing wet vent lfparker Plumbing 7 12-29-2015 08:10 AM
Tricky bathroom remodel - any suggestions? mannewskie Remodeling 8 04-03-2013 06:26 PM
Help with Bathroom Sink Supply Line RudySands Plumbing 3 02-07-2013 07:46 PM
slow draining bathroom sink jbkenn331 Plumbing 11 12-07-2012 01:13 PM
How to Remove Porcelain Bathroom Sink from Tile Countertop llander Kitchen & Bath Remodeling 1 11-27-2012 11:31 AM
