Attic Conversion - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-11-2015, 07:09 PM   #1
Rewards Points: 4
Attic conversion
Hi,
I have just bought a 3 bed 1971 house in the UK, and have been given a green-light to convert the attic. I want a home cinema, simple.
I have been reading around, and have a general idea, but there are still holes in my knowledge, that I am hoping to fill here:
i) How can I tell if any wall is load bearing
ii) How can I tell if the attic floor joints need reinforcing
iii) Is planning permission only required if the house is to be sold
iv) The house has soffits, but I am unsure how to deal with those; obviously the room I want needs to be weather proof, so is it correct to say I want to move the cold-room attic to a cold-roof equivalent
Thanks in advance.
n1md4 is offline   Reply With Quote
Old 05-12-2015, 07:23 AM   #2
Rewards Points: 4
I have found an answer regarding joists.
www home-extension co uk / tech2 html
(forgive the spacing, I've not yet posted enough for URLs)
Old 05-13-2015, 07:55 AM   #3
Rewards Points: 2,458
I'm in NJ, USA, and once I apply for a permit to build/add/make changes to a house, I am bound to finish according to the plan. If I sell the house, there is a process of inspection (called certificate of continuing occupancy) that is not related to a final building inspection. Permit to build will not allow you to sell.
Other questions, google your questions and you should get some idea what to look for. You should at least know what your foundation is and what kinds of material your house is built with.
carpdad is online now   Reply With Quote
Tags
attic conversion
Ridge vent vs mushroom fan gtothek Roofing/Siding 8 03-30-2015 02:12 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Insulating Attic Conversion Zidden Remodeling 3 02-11-2011 12:42 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
