Attaching Undermount Sink - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 04-09-2017, 11:56 AM   #16
Rewards Points: 322
Re: attaching undermount sink
As far as using minimal adhesive, what do you recommend? Since the sink rim would be sealed with silicone, would it be OK to do the granite with a few beads of silicone rather than industrial adhesive?
tns1 is offline   Reply With Quote
Old 04-09-2017, 01:12 PM   #17
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,266
You can lay down silicone on the wood and drop the granite on top.
That will hold it.
Why does your sink look like a drop in?
Did you put a straight edge across to make sure it's not sticking up? This could have disastrous consequences. The granite could crack eventually.
A bit lower than the wood is preferred.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is online now   Reply With Quote
Old 04-09-2017, 03:47 PM   #18
Rewards Points: 322
That will hold it.
The sink is a drop-in or "tile-in" type, but I am treating it as an undermount. There is more than enough added support under the plywood lip to guarantee it will never sag. The photo does not show it well, but this cast iron sink sits no higher than the plywood top, but because the sink rim is not perfectly flat the gap for the silicone might be almost zero in one spot but 1/16" at another. Also, all the granite slabs I have seen have a fiberglass netting on the underside. Is this netting normally sanded away in the area where the sink rim would contact? If so, it could add another 1/16" to the gap all around.
Old 04-09-2017, 05:10 PM   #19
123pugsy's Avatar
Don't know. I've only seen quartz and marble.
Give your supplier a call and ask.
Advice on Replacing Rusted Bath Undermount Style Sink mdonovan Plumbing 12 11-09-2013 02:36 PM
Resetting Undermount Kitchen Sink Voss Plumbing 0 02-24-2012 12:47 PM
undermount sink issues kyles Plumbing 1 12-12-2010 09:22 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
