Attached Carport As Living Space - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-14-2014, 10:32 PM   #1
Attached carport as living space
Hello,
I'm new here and am looking for some advice. I have an attached carport that I'd like to turn into living space. The carport is on a footing, but has a fairly flat "rubberized" roof. Most homes around me have enclosed their carports, but the difference would be the roof. I have little doubt that I could do the work myself if the roof isn't an issue.
VoteLibertarian is offline   Reply With Quote
Old 07-15-2014, 08:08 AM   #2
Rewards Points: 2,472
Last winter, on my street, one patio and one car port collapsed. I'd remove the existing car port and start new. Car ports also don't have continuous footing where you can build an enclosure that can support windows, floor, weather/water proof.
carpdad is offline   Reply With Quote
Adding Floor & Living Space to Attic Over Uneven Joists ziggy138 Building & Construction 18 02-06-2012 01:38 AM
Converting enclosed patio to living space sandiegoman Building & Construction 8 12-26-2010 10:49 PM
garage conversion into living space with bedroom brookendarren Building & Construction 3 12-15-2010 10:00 PM
closing vents in unused living space scottydel HVAC 1 12-05-2006 01:39 PM
Floor sealing on balcony over living space absorka Building & Construction 3 11-03-2006 06:36 PM
