Adding Shower To Alcove Whirlpool Tub - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2016, 08:02 PM   #16
Rewards Points: 32
there is already tile around the tub, does it look damaged? Baths are designed to shed water as people are expected to make a mess ie splash around a bit. I would have to agree with WhatRnsdownhill, i wouldnt worry just make it a shower.
surfing_santa is offline   Reply With Quote
Old 02-11-2016, 08:11 PM   #17
Tileguy
JazMan's Avatar
Rewards Points: 748
My first thought was for you to reconsider adding a shower head to this tub, it's not designed for a shower. It can work, but there's not enough room at the back and could be dangerous for some users. Also remember that the shower curtain inner liner would have to be on the inside of the tub further creating a smaller space. The remaining two corners will collect way too much water, and if level (as it should be), or if the tub is pitched slightly the wrong way, water will run to the floor.
I don't think it's gonna work so good.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-12-2016, 05:42 PM   #18
Amateuralex's Avatar
Rewards Points: 270
Originally Posted by ron45 View Post
Why have to cut any drywall...?
They have three piece shower kits.
Corner kits etc..
They have kits to meet every single need and if it looks like a no go, look again.
Forgot.... I would be more worried about the ventilation.?
I've had a lot of trouble finding a surround kit for a 60x42 alcove. I think I found one, but it's $900. I could tile it for $100.
Ventilation is no prob, there's a good bathroom fan already installed.
Amateuralex is offline   Reply With Quote
Old 02-12-2016, 05:48 PM   #19
Rewards Points: 270
Jaz
I was thinking of doing a shower door to address the curtain issue you raised.
I poured water in the corners and it appeared to drain pretty darn well.
I definitely appreciate your advice.
Theoretically I could pull the whole jacuzzi and install a base and surround. More effort and a lot more expensive. I'd rather have that, but with our newborn, $$$ is the main issue atm.
I got a quote from a respectable local company, and they said they'd tile the walls etc, much like my plan. They didn't raise any serious concerns, but I know that doesn't necessarily say that there aren't any.
Old 02-12-2016, 07:19 PM   #20
Rewards Points: 582
good luck...ben
Old 02-12-2016, 10:02 PM   #21
Tileguy
JazMan's Avatar
Rewards Points: 748
A door with that tub would be a really bad idea. You'd have to go with a curtain, but I don't think that's much better, cuz it'll get in your way.
Well, ok. If all four corners and the front slope into the tub maybe. But still lots of area to get wet and you should dry it with every shower.
Jaz
Old 02-12-2016, 10:07 PM   #22
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Boy, this is getting beaten like a dead horse from the negative nannies....
WhatRnsdownhill is offline   Reply With Quote
Alcove shower unit? CNM Design Building & Construction 0 03-15-2012 08:40 PM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
adding shower to a tub Ratz Plumbing 2 04-21-2011 11:15 AM
Adding a shower to a 1/2 bath amyjean Plumbing 1 09-10-2005 07:06 PM
