Acrylic Preformed 5 Foot Shower Base Padding? - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-19-2014, 03:35 PM   #1
Rewards Points: 4
Acrylic preformed 5 foot shower base padding?
Ive got this preformed 60 x 30 shower base to install over plywood floor with 2x6 subfloor the base does not lay down flush with floor and requires some sort of beding filler ive instaled sshower base before anf I had white sytrofoam as beding between floor and shower surface thi new one has nothing. Ive hearx of filling the underside of base with hot tar???? I like the tar idea but hot tar I hard to comd by and work with I need an alternate beding filler I waz thinking of taking tobues of slicone and filling I eiyh tha but that would be exspesive to many tubes.please help
rivasdaniel90 is offline   Reply With Quote
Old 10-19-2014, 03:47 PM   #2
Rewards Points: 17,884
delete
Old 10-19-2014, 03:52 PM   #3
delete
Old 10-19-2014, 03:58 PM   #4
By all the spelling errors I'm guess your the same person posting on doityourself.com
What's the directions on the website or the included directions with the base say to use?
Most use mortar.
No way do you want a flexible material?
No expanding foam, silicone, white foam, tar!
Hot tar would be used in an old style pored in place pan that's going to be tiled.
Buy a better quality pan as has been suggested before and no support is needed or it comes with it's own high density foam support.
Most use mortar.
100 % sure it's not the floor that's off not the pan?
No way would I be installing a tub or flooring over a 2 X 6 floor.
I'd install at least 3/8 subfloor rated plywood.
Old 10-19-2014, 04:08 PM   #5
Rewards Points: 270
I can't think of anybody,but maybe a cattle rancher,that could come up with that much semen.
flhtcu is offline   Reply With Quote
Old 10-19-2014, 04:17 PM   #6
Rewards Points: 582
hey guys be nice....
Old 10-19-2014, 07:57 PM   #7
Rewards Points: 4
Thanks for the seman idea ill get right on it lmao its not that I cant spell jdgas hate texting but im trying to get out of dinasorass state of mind
Old 10-19-2014, 08:18 PM   #8
Rewards Points: 4
The thinset will work thanks
Installing pre-formed shower base pan svaic00 Plumbing 4 05-22-2013 07:08 PM
Drain for preformed shower base svaic00 Plumbing 1 05-02-2013 10:11 PM
Shower base: which brand to go with? sukhenkoi Kitchen & Bath Remodeling 8 03-05-2011 01:19 PM
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
Pouring base for preformed steps justdon General DIY Discussions 3 09-01-2007 05:46 PM
