6 Inch Range Vent Hole Through 10 Inch Rim Joist - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-18-2016, 06:29 AM   #1
Rewards Points: 32
I think I already know the answer to this question, but wanted a few additional opinions.
I am working out the details on a kitchen renovation where my range will be moved into a peninsula near the center of the room. I want to vent the range hood up into the joist bay (2x10) and then out the side of the house through the rim joist to the outside. The only other interesting point is that this location is located above an existing sliding door. I will be up in the joist bay however, so I should be drilling well above the existing header for the door. This is a two storey home, and this kitchen is on the first floor.
Can someone please confirm that i am safe to drill a 6 inch hole through this 10 inch rim joist to get my vent outside?
Splash is offline   Reply With Quote
Old 02-18-2016, 07:02 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
I will take a guess that drilling through the rim joist should be fine, but the placement of a range exhaust sucks right over an entrance way..im sure there is a code one where you can exhaust smokey exhaust so it doesn get sucked back into the house..or blow on someone trying to get in or out...
WhatRnsdownhill is offline   Reply With Quote
Old 02-18-2016, 07:04 AM   #3
Rewards Points: 32
That is actually a sunroom out that door. The duct will go into the sunroon and then out the side of the sunroom. So in reality, the duct will not terminate over an entryway.
I left the sunroom detail out of my initial explanation, so I can see why that might concern someone.
Thanks.
Old 02-18-2016, 07:08 AM   #4
Thanks.
gotcha, then in that case it should be fine...as long as it meets code on distance of travel, that to me sounds like a loong distance for a fan to push exhaust in a residential setting...do you have any other shorter distances to run to get out of the structure?
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
Splash (02-18-2016)
Old 02-18-2016, 07:09 AM   #5
Rewards Points: 32
There is no shorter way unfortunately. I fit within the manufacturers guidelines on duct length (including the two elbows), but was unaware that there was a code which may limit this run in addition. Ill look into that.
Old 02-18-2016, 07:14 AM   #6
depending on where you live there are lots of codes for almost anything you do...many times they will side with what the manufacture recommends on an issue like that...I usually keep any paperwork on venting or installation to show an inspector if I think there will be any questions..
Splash (02-18-2016)
Old 02-18-2016, 07:16 AM   #7
Rewards Points: 17,880
Why can you not just go straight out through the roof?
Old 02-18-2016, 07:17 AM   #8
Rewards Points: 32
Its a two storey home, with a bedroom directly above.
Old 02-18-2016, 07:19 AM   #9
do you have a closet above to borrow a corner in to get into the attic?
Old 02-18-2016, 07:20 AM   #10
Rewards Points: 32
I dont. Its essentially right in the middle of the bedroom. I assumed that if I could do my horizontal run and fall within the manufacturers specs then I should be safe.
Old 02-18-2016, 07:24 AM   #11
you can offset to the outside wall like you want to going over the sun room, but go up before drilling the side plate..if there was a spot to go up on the 2nd floor..
Old 02-18-2016, 07:28 AM   #12
Rewards Points: 32
I thought about that, except you now how 3 elbows instead of the two in my original plan. Since each elbow counts as 10 feet of linear duct, Id be over the limit. I appreciate everyone's suggestions on trying to improve my duct flow, but my main concern is still drilling through the rim joist. (Although I would gladly shorter the duct run also if I could).
Old 02-18-2016, 07:34 AM   #13
if you go up instead of out the side, you can increase duct size and that would give you more distance....you just have to decide which way is easier and less costly..
Old 02-19-2016, 01:30 PM   #14
Rewards Points: 2,412
Use galvanized metal duct, tape and coat the seams. 6" duct is about the minimum for kitchen hood. Even the cheaper hoods I used came with 7" opening that could be reduced to 6" or equivalent. For longer distance, you may want higher cfm hoods and they may need bigger outlet. Instead of minimum you need, go size larger such as 7-8".
carpdad is offline   Reply With Quote
Old 02-19-2016, 07:13 PM   #15
Retired Moderator
Rewards Points: 7,174
Your plan is just fine--done exactly that same run several times---
Carpdad has an important point---most new hoods use 7" or even 8" ducts
If possible--upsize the duct---tin is cheap--reworking it in the future will not be---
Downdraft range vent exhaust placement problem Docman General DIY Discussions 2 08-02-2013 03:26 AM
new hole for dryer vent in cinder blocks jobblyman Concrete, Stone & Masonry 6 04-30-2013 08:21 AM
Dryer Vent through Rim Joist Branden Building & Construction 5 09-26-2012 11:55 AM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
