33" Sink Base/33" Sink - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-06-2014, 03:47 PM   #1
Rewards Points: 256
33" sink base/33" sink
So the standard sized 33" double bowl stainless sink fits snugly in a 36" sink base cabinet.
In my latest kitchen 3" really make a difference to the layout.
Does anybody have experience modifying a smaller sink base cabinet to fit a standard size sink?
I think I can jigsaw the cabinet sides down a bit to give room for the fasteners and make it work.
Yes, I know they make smaller sinks, I don't want one.
michaelcherr is offline   Reply With Quote
Old 12-06-2014, 04:59 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,122
A "standard" single bowl kitchen sink will fit inside a 30" sink base; maybe even a 27".
the standard sized 33" double bowl stainless sink fits in a 36" sink base cabinet.
That too.
I had a wife like that once too.
The Following User Says Thank You to TarheelTerp For This Useful Post:
MTN REMODEL LLC (12-06-2014)
Old 12-07-2014, 09:25 AM   #3
Rewards Points: 144
Yes ,you can cut the sides out of the cabinets for the sink to clear.
mako1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mako1 For This Useful Post:
ben's plumbing (12-07-2014), TheEplumber (12-07-2014)
Old 12-07-2014, 08:24 PM   #4
Rewards Points: 112
cutting the sides of the cabinet, like other people have said will work fine. The only hard part I have had doing that is attaching the clips for stainless sinks.
paul100 is offline   Reply With Quote
The Following User Says Thank You to paul100 For This Useful Post:
Old 12-09-2014, 07:06 AM   #5
Rewards Points: 2,432
Sometimes you need sink clips close to the corners as possible. That may mean not just cutting out some of the sides. You should just cut the side in half so you will have as much room as possible. Secure the top with angles or flat brackets.
But the next cabinets will/may lose the drawers. Change to center slider?
carpdad is offline   Reply With Quote
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 06:24 AM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 12:25 PM
