24 X24 Garage Exact Measurements - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 2 Post By SeniorSitizen
  • 2 Post By Daniel Holzman
  • 2 Post By ryansdiydad
  • 1 Post By carpdad
Old 03-03-2017, 11:34 AM   #1
Solutions (handyman)
Rewards Points: 462
24 x24 garage exact measurements
I have had several different answers so here is the question. For a 24' x 24' garage, are the measurements based on the concrete slab outside measurements or other? Is the framing, including the exterior sheathing, to equal 24' or does it also include the siding. I've also heard that it may be the interior measurements (wall to wall)?? I don't believe this is a matter of local codes, but would like to have some feedback from those who know.
Thanks.
Mark Harvey is offline   Reply With Quote
The Following User Says Thank You to Mark Harvey For This Useful Post:
abrowning (03-31-2017)
Old 03-03-2017, 11:42 AM   #2
Rewards Points: 1,466
Re: 24 x24 garage exact measurements
In my jurisdiction that would be determined by the tax assessor measured by which way brings in the most revenue.
Bondo and Dave Sal like this.
Old 03-03-2017, 12:11 PM   #3
Civil Engineer
Rewards Points: 5,246
The measurements on a properly developed drawing are always shown on the drawing itself. So an inside measurement will have a double ended arrow, or perhaps a line with two witness marks, showing where the measurement begins and ends. So on a properly developed drawing, there is never any question as to where a given measurement is taken.
If your question is more generic, i.e. if you bid a job that calls for a 24 ft square garage, is there a standard definition for whether this is a net measurement (inside dimensions) or a gross measurement (outside dimensions), I am not familiar with a universal standard. I always ask specifically where the measurements are to be taken.
abrowning and Bud9051 like this.
Old 03-03-2017, 12:33 PM   #4
Rewards Points: 1,514
Round here a 24x24 garage refers to the exterior dimensions... pretty much any general description of the size of a structure here would be the exterior dimensions..
Bondo and Mike Milam like this.
ryansdiydad is offline   Reply With Quote
Old 03-03-2017, 12:36 PM   #5
JUSTA MEMBER
Rewards Points: 3,574
In my area it is the outside measurements of the building, completed.
Say you have trim boards on the corners running vertical , The tax assessor measures from outside to outside, and you pay taxes on the entire sq. feet of that, even though you can't live in the wall spaces or siding.
ED
de-nagorg is online now   Reply With Quote
Old 03-04-2017, 09:56 AM   #6
Rewards Points: 2,452
Since I didn't let the tax assessor in, it is always outside.
Str8AheadInc likes this.
carpdad is offline   Reply With Quote
Old 03-04-2017, 06:45 PM   #7
Registered User
Rewards Points: 526
Local assessment rules. When framing (walls/floors/roofs) or concrete work (slabs/patios/garages) -in residential- the siding/sheathing is not included in the measurement, around here.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
jlhaslip (03-04-2017)
Old 04-02-2017, 09:29 PM   #8
Professional
Rewards Points: 188
Gary
Likewise where I live.
Str8AheadInc is offline   Reply With Quote
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 09:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
unconditioned garage reillyoevans HVAC 3 08-20-2011 06:29 PM
