100 Year Old Beams Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-28-2014, 12:51 PM   #1
100 year old beams question
HI, i am new here ,
I have 2 beams in my home one in basement and one on second floor and they are 6/9/16 - They run parallel with the floor joist which seems off to me; it is as if they wanted to use them as girders and changed there mind or some thing. I just can't figure out why these one are so much bigger then the other floor joist?
I should say this is a double boarded home and the beams are mortise and tenon into a perpendicular beam of equal size on each side of the room. they span about 16 ft
My question is why are these beams so big when compared to their neighboring floor joist.
bennythepitbull is offline   Reply With Quote
Old 03-28-2014, 06:51 PM   #2
Retired Moderator
Rewards Points: 7,174
Post a picture if you can---we have some members here that know old structures---
What country are you in?:
Old 03-28-2014, 08:21 PM   #3
Rewards Points: 298
Could be holding balloon framing together together. Probably walls pulling apart. Only thing I know is dont take it out.
JustinK is offline   Reply With Quote
Old 03-29-2014, 07:32 AM   #4
Rewards Points: 17,890
Really need that picture.
Another though is it's very common in older homes that over the years someone has removed some walls to "open" it up inside without taking into consideration if it's a supporting wall.
Old 04-01-2014, 08:33 AM   #5
I cant get a photo that would show ...
here are some drawings I did to show the camera wont do the trick :
100 year old beams question-top-vie-2nd.jpg   100 year old beams question-front-view.jpg
Old 04-01-2014, 01:08 PM   #6
a revised front view
PT beams warp or twist off posts? windowguy Building & Construction 5 09-06-2012 07:24 AM
Some ways to save money, and do PMs BigGuy01 Building & Construction 5 12-23-2011 02:46 PM
peeling year after year handifoot Painting 5 03-25-2010 06:45 PM
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 02:00 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
