Widening Door Jamb - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-04-2015, 02:49 AM   #1
Rewards Points: 281
Widening Door Jamb
HD has an awesome deal on some really nice pre-hung interior hollow doors for $109 a piece. My home was built in the early 60's so the wall material is a drywall/plaster hybrid which measures roughly 7/8" thick. The jambs on these doors are roughly 4-1/2", designed for 1/2" sheetrock walls... If I were to special order them with the correct jamb size, I'm looking at roughly $100 extra per door. My other option is to extend the jambs 3/4". If I were to do this, what would be the best way to attach these extensions and would they eventually crack at the butt joints? Is it worth the effort or would it be better to dump the jambs complete and build them from scratch and just use the door? Any suggestions
seephor is offline   Reply With Quote
Old 03-04-2015, 06:25 AM   #2
Retired Moderator
Rewards Points: 7,174
Put the jamb extenders on the latch side --so your hinges woll be set as designed,
set the jamb extenders in a bit--to create a reveal--this will disguise any out of perfect joints and allow the lock catch to clear the extender.
Old 03-04-2015, 10:10 AM   #3
Rewards Points: 18,088
Jamb extentions are done all the time with no issues.
A whole lot easier to install if you use a pneumatic finish nail gun.
I install the head piece first, then the two sides, that way the sides hold up the head piece.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
Larry K. (03-07-2015), mae-ling (04-19-2015), woodworkbykirk (03-04-2015)
Old 03-04-2015, 11:13 AM   #4
funflyer's Avatar
Rewards Points: 432
Use wood glue and the joint will never separate. A brad nailer makes the job much easier.
funflyer is offline   Reply With Quote
Old 03-04-2015, 02:43 PM   #5
Rewards Points: 2,600
are you taking about jamb extensions that are tongue and grooved, or just some pine flat stock to build it up? i suspect that latter, so just get some 3/4? flat stock at least as long as a door side, rip strips to about 7/8" (unless the drywall is too tight), and then glue and brad nail it, hold back 1/16"-1/8" from inside jamb edge (reveal as was mentioned), lightly sand the edge of the piece, prime, paint, done.
if the door jamb is already primed then i would hand sand the primer off before gluing, makes a much better joint, etc.
concrete_joe is offline   Reply With Quote
The Following User Says Thank You to concrete_joe For This Useful Post:
Old 03-04-2015, 06:35 PM   #6
Rewards Points: 281
Yes, just flat piece of stock to build it up. The jambs are primed so I will have to sand it off. There's also a 1/8" radius on the existing jamb. I can radius the extensions as well but once I glue and nail it, how should I fill the joint? Regular joint compound? wood filler? ALEX caulking?
Old 03-04-2015, 07:27 PM   #7
Retired Moderator
Step the jamb extender back so the radiused edge of the original still shows.
Old 03-04-2015, 07:32 PM   #8
Davejss's Avatar
Rewards Points: 934
I always rip my jamb extesions a good 1/8" proud, and then fine tune them with my block plane after they're installed. Just make sure your nails are countersunk deep enough.
Davejss is offline   Reply With Quote
Old 03-04-2015, 10:28 PM   #9
the joint, where glue meets old and new, will be hidden as you hold the new piece back from the original radius, and then when you prime and paint it will basically disappears, etc.
Old 03-06-2015, 09:29 PM   #10
funflyer's Avatar
Rewards Points: 432
The last door I installed, I pulled the staples out and disassembled the jambs then ripped them a quarter inch on the table saw to remove the radius and primer. It was much easier to add the extension and reassemble the frame so it looked perfect.
Old 03-06-2015, 09:45 PM   #11
Rewards Points: 29
Just go to a door shop and see what they charge for a prehung door with the right size jambs. It probably cheaper than big box. Adding jambs extensions to one that was miss ordered is one thing, doing it to a hole house just looks like someone got a deal and made it work. Just my opinion.
The door shops usually have nicer stop and include casing and you can get 1/4 radius hinges. They look nicer. All for around $200~
philmy is offline   Reply With Quote
Old 03-07-2015, 01:18 PM   #12
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Being in the remodeling business, we apply extension jambs all the time.
Windows, doors, archways you name it.
When I order new windows they ask if I want the extension jamb kit for $$$
I never buy the factory jambs. It's not cost effective and they very rarely fit perfectly.
I just buy select or knot free lumber to rip my own extensions. It gives me more control of the finished product.
We generally apply the extension to the non hinged side like others here have so expertly expressed. That way the hinge operation is not affected.
If it's a good deal and a door you like, don't be afraid of performing a common task that's done in carpentry/ remodeling every day.
After all, you are remodeling and I'll bet you'll find this very easy once you get set up.
Good Luck
tcleve4911 is offline   Reply With Quote
The Following 3 Users Say Thank You to tcleve4911 For This Useful Post:
funflyer (03-07-2015), Larry K. (03-07-2015), oh'mike (03-07-2015)
Old 03-07-2015, 09:02 PM   #13
arent "extension jamb kits" the jamb being grooved and extension being tongued ??
the OP has std jamb currently (the door was good price, had to buy), so must cut rips, glue, and tack.
tcleve4911 (03-09-2015)
Old 04-19-2015, 04:23 AM   #14
Rewards Points: 281
Thanks for your advice. I did exactly this... pull the jambs apart, ripped about 1/8 to remove radius and primer, ripped the extend pieces, used wood glue and clamps to make them perfectly flush and nail gunned them on. Some areas had about a 1/64 offset which some sanding took care of. primed it and the joint is completely invisible
The Following User Says Thank You to seephor For This Useful Post:
Widening Grout Joints on Slate Flagstone Patio MrBill_DIY Concrete, Stone & Masonry 5 08-04-2014 10:12 PM
widening a narrow stairway going to the basement pmc183 Building & Construction 1 11-24-2012 05:45 PM
Widening entry door - temporary support benjamincall Building & Construction 2 12-10-2010 06:50 PM
Widening a door frame ErichRhom Remodeling 4 04-06-2010 03:32 PM
Considering widening interior doorway - How difficult? davewolfs Remodeling 11 05-23-2007 02:26 PM
