Where Can I Find This Hinge? - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 06-20-2019, 10:31 AM   #1
Rewards Points: 236
Where can I find this hinge?
Has anyone worked with or sourced this type of cabinet hinge recently? I have one that on longer sits in the door from the plastic breaking, am hopeful that I could just replace it. TIA
Where can I find this hinge?-2019-06-17_19-21-15_361.jpg   Where can I find this hinge?-2019-06-17_19-21-09_958.jpg
bluefish7 is offline   Reply With Quote
Old 06-20-2019, 11:11 AM   #2
retired framer
Rewards Points: 1,610
Re: Where can I find this hinge?
You will have to figure out if they are 1/2 or 1/4" overlay or buy both.
https://www.amazon.com/Amerock-Burni.../dp/B003ZWEHHM
de-nagorg likes this.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
bluefish7 (06-20-2019)
Old 06-22-2019, 08:07 AM   #3
Rewards Points: 236
Where am I measuring the overlay? Just basically the distance that the door covers the cabinet frame when closed? Thanks
Old 06-22-2019, 08:10 AM   #4
retired framer
Originally Posted by bluefish7 View Post
Where am I measuring the overlay? Just basically the thickness of the door? Thanks
It is how much wider the door is than the hole that is the cupboard.
Does the door cover some of the face frame. Does it cover 1/4" or 1/2" when the door is closed.
Old 06-22-2019, 09:49 AM   #5
Rewards Points: 236
seems to measure 3/8" so assuming thats really 1/2"
Old 06-22-2019, 10:13 AM   #6
retired framer
I am not sure that they don't make one that is 3/8" might be a bit of a crap shoot.
If you get the wrong size, you might have to space it out at the face frame or chisel a little to set it back a bit. I would order 2 so at least the two on the same door match.
