Ways To Conceal Vanity Gaps - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 05-08-2017, 11:41 AM   #16
jlhaslip's Avatar
Rewards Points: 708
Re: Ways to Conceal Vanity Gaps
There are jigsaw blades which are designed to cut on the down stroke for cutting the Laminate. A regular up cut one may chip.
A regular skil saw will do an okay job on the edges if you cut from the backside. Sharp blade is required.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-08-2017, 12:31 PM   #17
Rewards Points: 42
Skil circular or jigsaw, or doesn't matter? Assuming jigsaw would be needed to cut sink hole out?
JBG420 is offline   Reply With Quote
Old 05-08-2017, 12:49 PM   #18
jlhaslip's Avatar
Rewards Points: 708
Skil saw from the back side for straight cuts along the side and jigsaw with down cut blade for the sink hole.
Add some 5/8 or 3/4 material to the underside if the lip interferes with the doors. Can be glued/nailed to the case or the top.
Old 05-08-2017, 01:10 PM   #19
Rewards Points: 42
Ok thank you very much.
Old 05-10-2017, 07:48 PM   #20
Rewards Points: 42
Thanks for all the help. Dry fit it all today and happy with the results (so far).
Old 05-12-2017, 06:05 PM   #21
Rewards Points: 42
Anyone have thoughts on a creative back and aide splashes? Don't want to tile.
Old 05-12-2017, 08:09 PM   #22
Rewards Points: 1,882
Re back and side splashes, so you have any scraps left that are long enough?
ChuckF. is offline   Reply With Quote
Old 05-12-2017, 08:14 PM   #23
" I Can Fix It "
Mrbuilder's Avatar
Rewards Points: 170
Cultured marble comes to mind ? Maybe make them from the scrap sink cut out, a little heat from a hair dryer will usually allow removal of the laminate. Just remember to to remove ALL the old adhesive before re-use.
just sayin
" It's ok if you're not sure, find someone who is"
Mrbuilder is offline   Reply With Quote
Old 05-12-2017, 08:16 PM   #24
jlhaslip's Avatar
Rewards Points: 708
Mirrors all around? At least on the front wall you could go with a wide one corner to corner.
Then a molding along the sides.
Old 05-12-2017, 08:57 PM   #25
Rewards Points: 42
That's what was there originally, a mirror that took up the whole front wall. There were some "vinyl" strips (maybe 4" width) that were glued on to the walls and had a stainless metal border. Unfortunately I don't have enough scrap left to use the laminate from the cuts to finish the whole project and as luck would have it, this counter is no longer available so I can't buy another 4' section to cut up and work with. Might have to end up tiling it after all. Anyone know of any decorative vinyl strips like i'm talking about? Something similar to what was used previously?
Old 05-12-2017, 09:33 PM   #26
jlhaslip's Avatar
Rewards Points: 708
Yup. I have used them before to install Arborite as back splash. Not sure what they are called, or if they even have a specific name. That was years ago. 20 or more.
Tile would be your best bet.
Old 05-13-2017, 08:05 AM   #27
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,502
You have a pretty good fit.
A nice caulk joint would look good and not like a patch job.
jlhaslip likes this.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 11:21 PM
HVAC vent under bathroom vanity? RickSK Kitchen & Bath Remodeling 3 06-05-2014 09:01 PM
Controlling a fan/light combo AND a vanity with two switches domh Electrical 18 03-22-2012 11:06 AM
How to build/attach wall hung bathroom vanity NewHomeDIYGuy Carpentry 13 12-28-2011 03:17 PM
Offset Vanity Tops miltoda Building & Construction 0 12-19-2011 04:29 PM
