Undercabinet Lights On Thin Cabinet Bottom - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-20-2014, 09:41 PM   #1
Rewards Points: 35
Undercabinet lights on thin cabinet bottom
I am looking to install a set of under-cabinet LED lights for my wife for xmas, and I have everything all set to go.
But as I was sizing things up tonight, I discovered that the cabinet bottoms are only 1/4" ply - and the install says not to install on less than 1/2" material.
I can get shorter screws, but I'm concerned there wouldn't really be enough to bite into in only 1/4" plywood.
Can I go ahead as is? Or do I need to alter my plans and add another 1/4" thick or better shim on the inside?
KatHelms is offline   Reply With Quote
Old 12-20-2014, 10:07 PM   #2
chitownken's Avatar
Rewards Points: 510
Are you sure it's 1/4"? Doesn't seem that 1/4" would be sturdy enough to hold up much in the way of contents. Pretty much every cabinet I have seen has 1/2" or 3/4" material for the outside framing.
chitownken is offline   Reply With Quote
Old 12-21-2014, 11:04 AM   #3
Rewards Points: 996
get led strip lights. they work great, change colors if wanted. and are very easy to install.
Fix'n it is offline   Reply With Quote
Old 12-22-2014, 08:17 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Most under cabinet lighting is headed towards LED these days.
They're a peel n stick and use low voltage wiring to the light.
The driver/transformer is located in the basement, under the cabinet or some other remote location.
I agree with chit on the 1/4" concern. I'd double check that measurement.
tcleve4911 is offline   Reply With Quote
Old 12-22-2014, 09:18 AM   #5
ZZZZZ's Avatar
Rewards Points: 2,892
Why not just shim underneath (outside) of the cabinet? If you have standard box and face frame cabinets, it'll be hidden by the face frame and it won't show.
ZZZZZ is online now   Reply With Quote
Old 12-26-2014, 07:46 AM   #6
Rewards Points: 262
Hot glue or epoxy. Screws for metal studs are short, and washers or cutting the end (for predrilled holes) makes them adjustable. The transformer can also go on up of the cabinets.
carpdad is offline   Reply With Quote
Old 12-26-2014, 09:22 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 10,012
Like Fix said.....LED strip lights. No heat, uses a whole lot less energy. If you want to get fancy, you can get adjustable colors.
Trust me.....it's the only way to go now.
Old 12-27-2014, 10:20 AM   #8
Rewards Points: 996
when i rewired the kitchen i put regular switched outlets behind the cabinets. the transformer is screwed to the cabinet inside. no problems and works great.
Old 12-28-2014, 12:19 AM   #9
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
Let's not overthink this. A few strips of double sided tape will be plenty of adhesion. Make sure everything is clean and stick 'em on.
I hate signatures.
Mort is offline   Reply With Quote
are there any direct wire LED cabinet lights? raylo32 Electrical 3 11-25-2012 09:01 PM
Preparing for Under Cabinet Lights wewantutopia Electrical 12 11-21-2012 07:34 PM
Remote mounting of transformer for under cabinet lights mtnears Electrical 7 07-27-2012 08:55 PM
Under cabinet lights dismas Electrical 3 01-15-2010 04:52 PM
kitchen under cabinet lights DIYGST Electrical 1 01-05-2009 02:01 PM
