Trouble Fitting A Pigs-ear Handrail - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By BigJim
  • 1 Post By ClarenceBauer
Old 10-05-2018, 12:37 PM   #1
Rewards Points: 36
Trouble fitting a pigs-ear handrail
For a neat look in our hall, we're wanting to fit a pigs-ear handrail directly to the brick, rather than mounted to another piece of wood.
The problem is, the wall is made of hollow bricks... kind of like a tile/ceramic material that's easy to crack/smash.
I've fitted a heavy oak shelf into these bricks using some chunky screws (cavity anchor screws didn't work, due to the thickness of the bricks) and a heavy-duty bracket, so the weight is distributed.
I'm worried that seems we don't want to use a bracket for the handrail, it's going to be weak/dangerou in these kind of bricks.
Am I worrying over nothing, or are there any other workarounds I can do that don't involve mounting the handrail to another piece of wood?
Thanks!
robnights is offline   Reply With Quote
Old 10-05-2018, 10:02 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 290
Re: Trouble fitting a pigs-ear handrail
Not knowing how thick the bricks are I am going to guess less than an inch. You can find a stud in the wall at intervals, and using a diamond hole cutter, cut the brick, and insert a wooden circle to fit in the hole, then secure the rail to the wooden circles.
de-nagorg likes this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
robnights (10-07-2018)
Old 10-05-2018, 11:26 PM   #3
Rewards Points: 148
You can use a composite mesh sleeve for epoxy anchoring.
It is a sleeve that you insert in to the hole drilled in the clay block than epoxy is injected into the port of the sleeve the screen causes the epoxy to spread out on the back side of the block wall a stud is than put in the epoxy when cured it is solid. Check Hilti @ HD
Johnny_inFL likes this.
ClarenceBauer is offline   Reply With Quote
Old 10-07-2018, 05:53 PM   #4
Rewards Points: 36
@BigJim , yes the bricks are less than an inch thick. Do you have a picture of what you mean, as I'm not sure I'm following properly? How would you get the wooden cicrle to stick? Just some adhesive?
Old 10-07-2018, 05:57 PM   #5
Rewards Points: 36
@ClarenceBauer , sorry, stupid question, but what do you mean by a "stud"? A piece of wood, or a stud bolt? Thanks!
Old 10-07-2018, 06:39 PM   #6
Rewards Points: 148
A threaded Stud , All thread Rod.
Even some like a sleeve type anchor or a power stud. ( it has a wedge at the inserted end )
Old 10-07-2018, 09:11 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 290
Sorry, a stud is a 2X4 that the wall is framed with.
I would glue then lag bolt or use 3 1/2-4 inch large thread screws. If using a lag bolt you will need to counter sink the bolt head. When you attach the rail to the round plugs, it will cover the fasteners.
Jim
Old 10-07-2018, 10:14 PM   #8
Rewards Points: 148
Yes a stud is an upright support in a wall of a building to which sheathing , drywall , etc. are attached.
A stud is a large - headed piece of metal that pierces & projects from a surface.
A power-stud ( trade mark ) anchor is a one piece fully threaded wedge style anchor.
A male horse is referred to as a STUD.
sorry I missed used the word stud.
The poster was asking about having a back up material that appeared to be some kind of clay block/ brick that was easy to crack / smash so using an epoxy would enforce a larger area in that type of material. So I used an example from Power fastener hand book Page # 15 Power - Stud with a wedge.
Old 10-07-2018, 10:30 PM   #9
Rewards Points: 148
Maybe I should have instructed the poster to use a Snake ( trade mark ) for use in concrete? This would be an internal threaded insert 1/4 inch dia. or 3/8 inch. That the poster would insert into the sleeve with epoxy injected.
Old 10-09-2018, 07:18 AM   #10
Rewards Points: 36
Perfect. Thanks for all the info, everyone! I'll give this a try over the weekend
Leaking CPVC fitting fixed itself? tom_poconos Plumbing 3 06-05-2018 04:22 PM
Pig's Ear handrail woodyjohn Carpentry 9 11-28-2014 04:08 PM
Easiest way to go from 1/2" ball valve to 1/4 inch compression fitting? Studly Plumbing 11 11-03-2011 08:57 AM
trouble fitting 4 wires into three demondope Electrical 11 12-28-2007 12:58 PM
