Trimming Toe Kick - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Nealtw
  • 1 Post By CaptTom
  • 1 Post By Nealtw
  • 1 Post By daveb1
Old 08-16-2018, 08:13 PM   #1
Rewards Points: 249
Trimming toe kick
I just installed some cabinets I purchased at Lowe’s for my garage. I tried dry fitting the toe kick which is 96 inches long. It is exactly 4 inches wide as is the space it is filling. It got stuck when I was trying to get it out so I need to shave off a little. What is the best way to do this?
Ranger1227 is offline   Reply With Quote
Old 08-16-2018, 08:36 PM   #2
retired framer
Rewards Points: 4,662
Re: Trimming toe kick
What have you for ,saws, sanders, planes, router and what would you like to tell the wife you need?
Old 08-16-2018, 08:42 PM   #3
Rewards Points: 48
Sounds fairly serious, better get this one …..
Gregsoldtruck79 is offline   Reply With Quote
Old 08-16-2018, 09:00 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 716
Do you mean you need to make it shorter than 96" or you need to make it narrower than 4"? If the latter, is it tight all the way or is your garage floor slightly uneven/sloped?
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 08-16-2018, 10:58 PM   #5
Rewards Points: 249
I need to make it narrower than the 4 inches. 96 is the righ length. I placed the cabinets ove those rubber garage squares to keep them off floor so they do not absorb water when I clean garage or from melting snow
Old 08-16-2018, 11:00 PM   #6
Rewards Points: 249
It is tight the whole way across
Old 08-16-2018, 11:02 PM   #7
retired framer
Table saw would be first choice.
Old 08-16-2018, 11:03 PM   #8
Rewards Points: 249
Yes but mine is currently out of commission. I was thinking of sanding the edge
Sent from my iPad using Tapatalk
Old 08-16-2018, 11:16 PM   #9
Rewards Points: 5,000
If you cut 1/8" off the top edge you will not see it when installed.
ron45 is online now   Reply With Quote
Old 08-16-2018, 11:45 PM   #10
retired framer
Some of the lumber yards can be talked into a cut for a couple $s
lenaitch likes this.
Old 08-17-2018, 07:19 AM   #11
Rewards Points: 2,538
Originally Posted by Ranger1227 View Post
...It got stuck when I was trying to get it out...
Do you plan on taking it out regularly? Maybe I'm just lazy, but I'd jam it in once and leave it there.
Nealtw likes this.
CaptTom is offline   Reply With Quote
Old 08-17-2018, 07:46 AM   #12
retired framer
Don't force it, use a bigger hammer.
CaptTom likes this.
Old 08-17-2018, 01:00 PM   #13
Rewards Points: 50
Following Murphy's law, if you put it in there real tight, then somehow, someway, sometime, something very important will drop and get in there.
CaptTom likes this.
daveb1 is online now   Reply With Quote
New thermostat wont kick over buner... need a little help from the pros.. speakeasy2009 HVAC 17 11-03-2015 03:07 PM
Installing Toe kick on ultracraft cabinets elsewhere Kitchen & Bath Remodeling 3 09-01-2015 10:35 AM
Need to close the gap between my new vanity's toe kick and my tile monnjohn Kitchen & Bath Remodeling 11 05-22-2015 08:08 AM
tile around kitchen island and around kick plates cmlcsu Flooring 4 01-08-2012 11:35 PM
quietest toe kick heater mazzonetv Plumbing 2 01-24-2010 02:36 PM
