Trimming Brickmold - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 02:10 PM   #1
Trimming Brickmold
Hi,
First-time poster here. I'm installing an exterior storm door. My door opening between brickmold pieces is about 35.5". The door I want comes in 36". Would it be feasible to cut a chunk of the brickmold off? I think there's enough room to make this work, though I'm a little intimidated either cutting sloppily or just being wrong about this idea.
Part two of my question is only applicable if you think this is a good idea. If so, what / how should I cut it? Could I chisel it away? Is there a better tool?
Let me know if you have questions as I may not be explaining properly!
Thanks!
ianso is offline   Reply With Quote
Old 11-21-2010, 04:52 PM   #2
kwikfishron's Avatar
Rewards Points: 68
Yes you can do it.
Chisels and chunks aren’t the way to go though.
Your best bet would be to pull off the trim, run it through a table saw and reinstall.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
jlhaslip (11-21-2010)
Old 11-21-2010, 05:01 PM   #3
Rewards Points: 5,348
These 36" doors will fit in a small range of openings. It should fit in the 35 1/2" opening you have without brick mold chopping.
It will state the range on the box.
Ron
Old 11-21-2010, 06:04 PM   #4
Rewards Points: 68
35 7/8" min. for a Larson.
Old 11-21-2010, 07:29 PM   #5
Thanks for the replies.
The door itself "fits" but not with the zbars on both sides installed in the proper position (so it doesn't really fit). The instructions state it can fit a minimum of 35 3/4" and it definitely is shy a good 1/4".
I think my options are:
  1. Chisel a piece off. Benefit is I can do it in place, without too much hassle, but it may come out weird. The cut will be partially visible (part of it will be visible in between the two doors).
  2. Take off trim and cut with table saw. Benefit is a better cut. Negative is taking it off, especially since it looks like it's a few pieces fit together (don't ask me why it's not a solid piece). Also, it's kind of a weird cut. I need it to be cut the long way so it's narrower. I guess I could use a plane too, but when discussing the chisel option I was thinking about taking a corner/edge off the length of the wood (if that makes sense).
  3. Build a new brickmold frame for the storm door dimensions.
  4. Return the door.
I'd prefer not to do the latter. I think I can make it fit using the existing brickmold if I trim it, though I'm not opposed to making a frame of sorts for the storm door.
Anyways, thanks for the replies. If you have any other thoughts, please share, else wish me luck!
Thanks!
Old 11-21-2010, 08:25 PM   #6
Retired Moderator
Rewards Points: 7,174
A router would cut off most of that--then a chisel--
I do think pulling off the molding and making a narrower on on a table saw will be faster and look better,
Old 11-21-2010, 10:29 PM   #7
remodeling pro
Leave the chisel in the garage, The only way to do this decently is to remove and run the pieces through a table saw.
There are two potential problems to be aware of.
1. ripping the edge of the brickmold down the inside(short side of the miter edge) will leave a small triangle missing when the miter goes back together. I don't see this as a problem, as the flange on the storm door should be wide enough to hide it.
2. Depending on how the door jamb is fabricated, ripping 1/4" off the trim could leave a very minimal amount of the brickmold on the doorjamb, so you will need to be carefull when nailing it back onto the jamb. It would be a good idead to shim the jamb liberally, as the brickmold will most likely not do a very good job of holding the jambs in place nailed along the very edge of the jambs as they will be. If you have a "modern" rabitted factory door unit, this should not pose as much a problem, as the jambs will be 5/4 material, but if an older unit with only 3/4" jambs and applied stops, the above situation will come into play.
troubleseeker is offline   Reply With Quote
Old 11-22-2010, 10:29 AM   #8
As you reduce the inner flat part of the brick mold you might need to knock off part of the face profile so the storm door frame sits flat on the brick mold face.
Ron
Old 11-23-2010, 09:59 PM   #9
remodeling pro
Ron
Good catch Ron
Old 11-26-2010, 06:40 PM   #10
35 5/8 for an Emco!
Of course, if it's a wood door, then cut the door. Otherwise do as someone else said and remove both side mouldings and rip an equal amount off each
mrgins is offline   Reply With Quote
Old 11-27-2010, 09:54 AM   #11
Thanks!
Hi everyone,
I just wanted to thank you for the help. I was able to cut the wood brickmold trim slightly on one side giving me enough room to fit the door together. It was only very slightly too small, and now that it's all together, you can't even tell I had to cut it. Yay!
Thanks again!
passageway trimming anthonyr Carpentry 2 04-03-2010 07:55 PM
Trimming Cypress Pines droopdog7 Landscaping & Lawn Care 1 07-21-2009 04:40 AM
trimming base of post wombosi Carpentry 3 10-05-2008 10:59 AM
Tree Trimming - Distance From Power Lines jamiedolan Landscaping & Lawn Care 8 09-14-2008 04:22 PM
Vinyl siding brickmold rjniles Building & Construction 1 02-05-2007 11:55 AM
