Stairwell With Different Heights At Each End? Which To Design Stairs For? - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 02-04-2018, 07:59 AM   #1
Rewards Points: 26
Stairwell with Different Heights At Each End? Which to Design Stairs For?
Morning Everyone. I am in the midst of designing a 1/4 turn stair way for my log home...new build. The problem is that the stairwell opening on the main level to the basement has a different height at each end, due to the slope of the concrete below.
The stairwell is 129.5" long
At one end its 100.25" in height
And the other end is 102.5 in height..
which height do I use to design?
Many Thanks
rinse is offline   Reply With Quote
Old 02-04-2018, 08:19 AM   #2
Rewards Points: 1,265
Re: Stairwell with Different Heights At Each End? Which to Design Stairs For?
I think the proper thing to do would be to use floor leveler to give yourself a level 3x3 landing pad at the bottom... (at 100.25") and make any slope occur outside the landing area.
By code, no step on a staircase can vary in height by any other step (on the entire staircase) by more than 3/8".
If grinding the high spots would help that is an option too.
Gregsoldtruck79 likes this.
XSleeper is offline   Reply With Quote
Old 02-04-2018, 09:25 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 22,714
I would pick the mid point between of the two and adjust the bottom step accordingly. One side short 1-1/8. One side long 1-1/8.
Old 02-04-2018, 09:43 AM   #4
Rewards Points: 928
Not quite sure I follow you. I assume you don't mean that you have 2 1/4" from one side of the last tread to the other side!
You measure the total rise from the point on the upper floor where the stairs start to point on the lower floor where the stairs will end. Nothing else really matters. I usually do a ballpark calculation of riser height to get a count of the treads, then I can measure where the last tread will land, and then I measure my total rise from there using a laser or a spirit level.
If you do have a difference in height from one side of the step to the other, you'll want to make sure that nowhere is the last riser higher than allowed by code. Makes sense to use the middle of the tread because that's where people walk, but I got busted once by a building inspector because I calculated the rise from the center of the tread, but i just went over on one side because the floor had a wicked slope.
Marson is offline   Reply With Quote
Old 02-04-2018, 09:57 AM   #5
CodeMatters's Avatar
Rewards Points: 6,188
What about pouring a flat concrete landing? Could make it whatever thickness
that leaves good step heights.
CodeMatters is offline   Reply With Quote
Old 02-04-2018, 10:57 AM   #6
Super Moderator
joed's Avatar
Well if the height on one side is 100.25 inches and height on the other side is 102.5 inches then YES you have 2-1/4 difference between the two sides.
Old 02-04-2018, 11:05 AM   #7
jlhaslip's Avatar
Rewards Points: 708
The measurement for the total rise needs to consider the elevation change from where the stairs start to where the stairs actually land. Calculate the rise based on this measurement. It does not matter if the floor under the stairs is up or down, only the point where the stairs land is critical.
t.carpenter00 likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-04-2018, 11:17 AM   #8
Rewards Points: 928
The OP said "end" not "side".
Old 02-04-2018, 11:59 AM   #9
Super Moderator
joed's Avatar
Well if the side to side measure at the end of the steps is equal then just use that measurement for the step calculations.
The other option is to build a level platform at the bottom and build the steps to that.
I guess we need some clarification.
Old 02-04-2018, 12:26 PM   #10
Rewards Points: 574
I am reading something like this.... maybe OP will clarify though.
Disclaimer: Any of my replies, advice, product recommendations, or projects that I have done that I post on this forum, are just for informational purposes only. Any reader choosing to use my postings, advice, product recommendations, or choose to duplicate any of my projects for their own use...are doing so at their own risk.
Gregsoldtruck79 is offline   Reply With Quote
Old 02-04-2018, 03:04 PM   #11
Rewards Points: 26
@Gregsoldtruck79 yes...like that. So I should just use the dimensions of where the stairs will land.
I have been thinking most of the day about this...I think I might build the landing first... then i just need to worry about two sets of straight steps, based on the landing height.
Old 02-04-2018, 03:44 PM   #12
jlhaslip's Avatar
Rewards Points: 708
You still need to consider the overall height to calculate the placement of the landing.
Old 02-04-2018, 06:18 PM   #13
Rewards Points: 574
Just a thought that may not be needed but,
Old 02-04-2018, 10:12 PM   #14
retired framer
Rewards Points: 14,572
You can loose or gain 1/4 inch per step so you could adjust one side 9 risers.
Or just do the math individual for each stringer. Then if you need a third stringer trace them both and cut a line centered between the two lines.
Hopefully you have 9 steps to the landing. If you can't get it all in 1/4" for each leave any extra error on the high side on the bottom.
Old 02-05-2018, 10:31 AM   #15
Rewards Points: 3,868
If I'm understanding this correctly
You have a 2.5" height difference in just 36"
If so, your problem is more then just the steps.?
ron45 is offline   Reply With Quote
Current house - stairs JulieB Project Showcase 20 04-09-2013 01:38 PM
Need help with stairs rogers_t Carpentry 11 02-26-2013 11:30 AM
How to finish basement stairs mark2741 Flooring 9 11-13-2012 12:09 AM
Outdoor stairs need to be fixed... 2031pratt Carpentry 4 12-01-2011 05:55 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 11:50 AM
