Rustic Table Metal Legs?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-17-2014, 09:42 AM   #1
Rewards Points: 8
Hi All,
I'm working on a rustic table, which I am modeling after the following side table:
http://www.wayfair.com/Convenience-C...7-CVC1584.html
I haven't been able to find any metal legs similar online though. Does anyone know where you can buy such legs online?
handygrad89 is offline   Reply With Quote
Old 11-17-2014, 10:16 AM   #2
Rewards Points: 1,466
Not sure where to buy metal....but why not just wood and paint it black? Ron
ront02769 is offline   Reply With Quote
Old 11-17-2014, 10:27 AM   #3
Rewards Points: 8
I'm trying to get a rustic look to the table with mixing salvaged wood and metal. I like the idea of using wood though if I am unable to find the metal legs
Old 11-17-2014, 10:40 AM   #4
Rewards Points: 2,608
Most every city of say 50,000 population and above will have a steel supplier. Ask for rectangular tubing, select the wall thickness and dimensions desired and most will cut it to length while you wait.
Old 11-17-2014, 11:42 AM   #5
Rewards Points: 18,118
Nothing really "rustic" about that table.
Any machine/welding shop could make that easy.
Not only do you need the legs to make that one, but the supports to set the tops on.
Unless you own a band saw and a welder it would be best to have it made.
Those legs are not an off the shelf item.
Old 11-17-2014, 12:29 PM   #6
Knows Enough to be Danger
Rewards Points: 1,231
THIS. Or any fab shop would likely have some shorter pieces of drop they'd sell reasonably.
Even Home Depot has short lengths of tube. Not sure about rect tube, though
NickTheGreat is online now   Reply With Quote
Old 11-17-2014, 01:21 PM   #7
Oso954's Avatar
Rewards Points: 318
Before buy the rectangular tubing, think about how you plan to protect the floor from it. Open ended tubing will scratch the heck out of a floor.
As Joe said, "Unless you own a band saw and a welder it would be best to have it made."
Or, make them out of hardwood.
Oso954 is online now   Reply With Quote
Old 11-17-2014, 02:03 PM   #8
Super Moderator
joed's Avatar
Rewards Points: 29,540
A wooden plug in the end of the tube should be easy to make and install to protect the floor.
If you are good with a drill and bolts you could probably do most of this without welding.
Old 11-18-2014, 09:55 AM   #9
Low Slope Roofing
Rewards Points: 114
Looks like a L shaped bracket was bolted or welded to support the shelfs.
Our steel supplier charges us 6 bucks a cut. I would look for some very thin wall tubing a sawzall will cut even up above 10 gauge metal. Even a skill saw with a metal blade.
1985gt is offline   Reply With Quote
Metal Edging and Odd Connection Point on Wall cloves Tiling, ceramics, marble 4 06-21-2014 05:34 PM
metal sheathing DiegoJames Electrical 2 07-01-2013 07:59 AM
Recommendations for roof type when reroof daluu Roofing/Siding 24 12-07-2012 03:23 PM
I feel dumb - how to attach something to metal Zephie General DIY Discussions 3 07-11-2012 07:37 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
